Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Acer Aspire 3 A315-22G - NB8607G02-MB (Compal LA-J761P) - BIOS Password Removal / Clean BIOS Needed
Hello everyone!
I want to express my sincere gratitude to user
Sparo for helping me unlock the BIOS! π
Laptop: Acer A315-22G (AMD A6-9220e, Radeon R4)
Problem: BIOS was password-protected, and the
password didn't work.
After contacting Sparo, I received a hint code
and the universal password 12345, which successfully
unlocked the BIOS. I immediately removed the
password (Set Password β empty field), disabled
Secure Boot, and configured boot from USB.
If anyone needs a BIOS dump for this laptop
(Acer A315-22G) β feel free to download the
dump I attached. It's working, password 12345
works, BIOS is unlocked. Can be used for
restoration or chip replacement.
Thanks again to everyone who helps the community! π
Photos attached.
β NEW PROBLEM (not related to BIOS):
β Laptop works stably with the original
soldered 4GB DDR4 RAM
β Decided to add an 8GB stick for upgrade
β RAM stick: KINSOTIN DDR4-8GB-NB-3200MHz
(P/N: N432CXBMB, Made in China)
Photos attached.
β Problem:
- I insert the stick into the free slot (until
it clicks, latches closed)
- I turn on the laptop: fans spin, indicators
light up, BUT NO SCREEN BACKLIGHT β screen
is completely black
- Waited up to 9 minutes (for memory
initialization) β didn't start
- I turn off, remove the stick β laptop
immediately boots normally with original 4GB
π§ What I've already tried:
- Reset BIOS to factory defaults
(Load Defaults)
- Disable Secure Boot
- Install official drivers from Acer website
(Chipset + VGA)
- Clean RAM stick contacts with an eraser
- Reset EC (power button 60 sec without battery)
π‘ Questions to the community:
1. Is the 3200MHz KINSOTIN RAM stick compatible
with AMD A6-9220e processor?
- CPU: AMD A6-9220e (1.6 GHz Base /
up to 2.4 GHz Boost)
- Memory controller officially supports
DDR4 up to 2400MHz
- In practice, system runs at 1866-2133MHz
2. Could the problem be with the SPD profile
or timings of the Chinese RAM stick?
- It's known that budget sticks sometimes
don't correctly provide data to the controller
or don't support downclock below 2666/2400MHz,
causing older AMD APUs to fail POST initialization.
3. Is it worth trying to update BIOS or edit
SPD timings via programmer, or is this a
hardware incompatibility, and easier to return
the stick / look for DDR4-2400MHz from trusted
brands?
π Full laptop specifications:
- Model: Acer Aspire 3 A315-22G
- Processor: AMD A6-9220e (1.6 GHz Base /
up to 2.4 GHz Boost, 2 cores)
- Graphics: AMD Radeon R4 Graphics (integrated)
+ AMD Radeon 530 (discrete, 2GB)
- RAM: 4GB soldered (DDR4, runs at 1866MHz)
+ 1 SO-DIMM slot
- BIOS: version 1.09 (haven't updated, have
backup via RT809H programmer)
π§ Skills: have repair experience, soldering
station, RT809H programmer β ready for advanced
methods if there's a chance.
I would be very grateful for any advice! Thanks
in advance to everyone who responds. π -
You had me doubt it for a split second lolHi Sparo!!!
IT WORKED!!! THE PASSWORD 12345 WORKED!!! πππ
I'm so sorry for the confusion earlier β I must have entered it incorrectly
when I tried before (maybe a typo, or I missed a digit, or the keyboard layout was wrong).
It was totally my mistake! Please forgive me for doubting! π
Thank you SO MUCH for your help, patience, and expertise!
I was struggling with this BIOS password for so long, and you saved me!
You're absolutely AMAZING! My laptop is finally unlocked and I can use it again!
You're a HERO! ππ
Thank you thank you thank you!!!
Best regards,
Olegst44
The important thing is that it's all sorted out and You're welcome!
Enjoy Your unlocked machine πLeave a comment:
Hi Sparo!!!
You're a HERO! ππ
Best regards,
Olegst44Leave a comment:
Hi again Olegst44 ! Remember this is an English ONLY Forum
Take some time to read the Forum's rules > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
Also for the websites you posted, they only work when the hint unlock code is all decimal keys (8 digits, 10 digits) e.g. 81256749 Yours is a hex key 956B1AEE
That said, I don't know why the password 12345 didn't work for you? It's the correct decoded password but I'll look into this again tomorrowLeave a comment:
ΠΠ΄ΡΠ°Π²ΡΡΠ²ΡΠΉΡΠ΅, Sparo!
Π‘ΠΏΠ°ΡΠΈΠ±ΠΎ Π·Π° Π²Π°ΡΡ ΠΏΠΎΠΌΠΎΡΡ!
Π ΡΠΎΠΆΠ°Π»Π΅Π½ΠΈΡ, ΠΏΠ°ΡΠΎΠ»Ρ 12345 Π½Π΅ ΠΏΠΎΠ΄Ρ ΠΎΠ΄ΠΈΡ ΠΏΡΠΈ Π·Π°ΠΏΡΠΎΡΠ΅ BIOS.
Π‘Π΅ΠΉΡΠ°Ρ ΠΏΠΎΡΠ»Π΅ 3 Π½Π΅ΡΠ΄Π°ΡΠ½ΡΡ ΠΏΠΎΠΏΡΡΠΎΠΊ Π²Π²ΠΎΠ΄Π° ΠΌΠΎΡ ΡΠΈΡΡΠ΅ΠΌΠ° ΠΏΠΎΠΊΠ°Π·ΡΠ²Π°Π΅Ρ Unlock Key Hint: **956B1AEE**
Π― ΡΠΆΠ΅ ΠΏΡΠΎΠ±ΠΎΠ²Π°Π» Π½Π΅ΡΠΊΠΎΠ»ΡΠΊΠΎ ΠΎΠ½Π»Π°ΠΉΠ½-ΡΠ΅ΡΠ²ΠΈΡΠΎΠ² Π΄Π»Ρ ΡΠ°Π·Π±Π»ΠΎΠΊΠΈΡΠΎΠ²ΠΊΠΈ BIOS:
- BiosBug.com
- bios-pw.org
- Π Π΅ΡΡ Π½Π΅ΡΠΊΠΎΠ»ΡΠΊΠΎ Π΄ΡΡΠ³ΠΈΡ
ΠΡΠΎΠ±ΠΎΠ²Π°Π» ΠΌΠ½ΠΎΠ³ΠΎ ΡΠ°Π· Ρ ΡΠ°Π·Π½ΡΠΌΠΈ Π²Π°ΡΠΈΠ°Π½ΡΠ°ΠΌΠΈ, Π½ΠΎ Π½ΠΈ ΠΎΠ΄ΠΈΠ½ Π½Π΅ ΡΡΠ°Π±ΠΎΡΠ°Π».
ΠΡΠ»ΠΈ Π²Ρ ΠΌΠΎΠ³Π»ΠΈ Π±Ρ ΠΏΠΎΠΌΠΎΡΡ ΠΌΠ½Π΅ Ρ ΠΏΡΠ°Π²ΠΈΠ»ΡΠ½ΡΠΌ ΡΠ°ΡΡΠΈΡΡΠΎΠ²Π°Π½Π½ΡΠΌ ΠΏΠ°ΡΠΎΠ»Π΅ΠΌ Π΄Π»Ρ ΠΌΠΎΠ΅ΠΉ ΠΏΠ»Π°ΡΡ NB8607G02-MB, Ρ Π±ΡΠ» Π±Ρ ΡΡΠ΅Π·Π²ΡΡΠ°ΠΉΠ½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°ΡΠ΅Π½!
Π‘ΠΏΠ°ΡΠΈΠ±ΠΎ Π·Π° Π²Π°ΡΠ΅ Π²ΡΠ΅ΠΌΡ ΠΈ ΠΏΠΎΠ΄Π΄Π΅ΡΠΆΠΊΡ!
Π‘ ΡΠ²Π°ΠΆΠ΅Π½ΠΈΠ΅ΠΌ,
Hi Olegst44 And Thank You for the Unlock Hint !! (This is for my own learning)Hi Sparo,
Thank you for the password (12345)!
Unfortunately, I still cannot download the file "A315-22G_BIOS_Ver_109.rar" β it shows "Premium supporters get full download access" error even after m1ch43lzm unlocked it.
As you requested, here's my Unlock Key Hint: **956B1AEE**
Any help would be greatly appreciated!
Thank you!
Best regards,
Olegst44
Also No need to download anything. I already gave you the BIOS password decoded from your BIOS backup
You can either keep the password, change it in the BIOS settings, or restore to factory settings to clear it
And You're Welcome, See you in the Forum!Leave a comment:
Hi Sparo,
Thank you!
Best regards,
Try, unlockedAttached FilesPremium supporters get full download access and other benefits.
Hi and Welcome to the Forum! Post the Unlock Key Hint it's showing YouHello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- After 3 wrong password attempts, system shows Unlock Key Hint
Thank you in advance for your help!
Best regards
I will myself Post this unlocked file extracted from the Acer Website same BIOS Version as yours but don't flash anything just Post the Unlock Key Hint first
Aspire A315-22G BIOS Version 1.09Attached FilesPremium supporters get full download access and other benefits.
Device Information:
- BIOS Chip: Winbond W25Q64 (8MB)
Problem:
- Boot from USB is disabled in BIOS
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password removed) for NB8607G02-MB
2. OR help with removing password from my original dump
I can:
- Read my original BIOS chip and upload the dump file
- Program a new W25Q64 chip with clean BIOS
I found "Acer Aspire 3 A315-22 NB8607 Rev1.0 BIOS" online, but I'm not sure if it's compatible with NB8607G02-MB revision.
Please help me with:
- Clean BIOS dump for NB8607G02-MB
- Or confirm if NB8607 Rev1.0 BIOS is compatible
- Or help remove password from my original dump
Best regardsTags: None
by newAttached Compal Schematics and board view for some Compal motherboards...
Channel: Schematics and Boardviews
05-20-2026, 10:51 AM -
by macabookHello everyone,
Iβm currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iβm at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereβs a full breakdown:
π§© Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by piratiHello everyone,
When the laptop arrived (without a charger and SSD), I connected a charger and confirmed with a multimeter that it was charging the battery. However, when I tried to power it on, only the backlight of the secondary display came on. There was no image, and it didnβt boot into the BIOS.
I decided to try flashing a new BIOS, but since I didnβt want to desolder...-
- Loading...
