bios request/fixing dump HP elitebook 840 G6
  • wrinex
    • Apr 2026
    • 8
    • Netherlands
    Hi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
    i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state (to confirm i can resolder them and the reader programmer works, and i did not screw up more in the meanwhike , ofcourse that remains to be seen) after the hp bios update. and the dump i post here. hope someone can help me out, i am new to this but would love to learn more and hopefully get this laptop back from the dead. even with security error.
    by the way i used a CH341 programmer, with the switch to sellect voltages 3.3 in this case. for what its worth
    Serial number:
    5CG9504XVH
    Product number:
    4WG32AV
    Board number:
    12/13 spsl62760-601
    kind regards Joppe
  • Sparo
    Quicksilver
    • Jan 2022
    • 2026
    • M\A
    • Anime, Edge Computing, Football, Snooker
    Serial number: 5CG9504XVH
    Product number: 4WG32AV
    Board number: 12/13 spsl62760-601
    kind regards Joppe
    Hi Jope and Welcome to the Forum! Try flashing both files from here
    > https://www.badcaps.net/forum/troubl...62#post3840462
    Enjoying our forum? Help keep it running and unlock extra perks!
    >> Upgrade here <<
    ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
    • wrinex
      • Apr 2026
      • 8
      • Netherlands
      oh thank you, i did use another one before i went back to the failed one, it had the 16MB and the 32MB, Orig+R70_010600 also from this forum. that one only gave me solid yellow on the power led, and nothing more.
      ill give it a try, if it does not work i have some more soldering under my belt
      thank you for your help and i wikll report back!
      • Sparo
        Quicksilver
        • Jan 2022
        • 2026
        • M\A
        Well if that's the case then flash only this 32MB file first
        If it doesn't work, flash the 32MB file from the link I gave you. If it still doesn't work then flash the 16MB chip as well
        >> Upgrade here <<
        ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
        • wrinex
          • Apr 2026
          • 8
          • Netherlands
          oh i flashed both... but now i get the solid yellow again.. problem is i then start doubting my own soldering skills... a resolder them a few times. but remains few blinks white then solid yellow
          resoldering them and the software stuff makes it rather hard, i keep asking myself if i might made a mistake in soldering... untill i solder them to the read out board witch works every time.
          • Sparo
            Quicksilver
            • Jan 2022
            • 2026
            • M\A
            Yes You need to check the soldering and make sure all pads are properly seated
            You can also solder only wires between the chip and the programmer if WSON8 soldering gives you a hard time although that's the easier route
            I still recommend practicing proper soldering I believe that's the best way to learn
            >> Upgrade here <<
            ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
            • wrinex
              • Apr 2026
              • 8
              • Netherlands
              yeah i was thinking about that. but it only works for the chip on the backside the 32Mb one. the other one has there pads under its chip without anything exposed i did order a clam that should be able to do Wson.. to bad this laptopm uses 2 sizes...
              • Sparo
                Quicksilver
                • Jan 2022
                • 2026
                • M\A
                Well You can also buy and use WSON8 probes, Google them (WSON 5x6 for 5x6 chips and WSON 8x6 for 8x6 chips) That way no soldering is required at all
                However for every chip read You should make 2โ€“3 backups and compare them to be identical before writing the chip. This way you know you've made a good read using the probe
                Your motherboard model is CRESCENT-6050A3022501-MB-A01(A1), right? The one you posted is wrong (12/13 SPSL62760-601)
                >> Upgrade here <<
                ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                • wrinex
                  • Apr 2026
                  • 8
                  • Netherlands
                  hmm i will look up those probes since soldering them everytime is not ideal i think thank you for all the help by the way !!
                  The motherboard name or id not sure how you call it, i posted is from the sticker in one of the ram slots... so what i think might have happened.... is the backplate might not be from this system. thats all i can think off. might explain why its not working either... but then i should go by the motherboard sticker i asume ? and ignore the maybe faulty backplate with serial number and model number ? what is the best way to go forward? i can explain why this might be the thing. i aksed a person that works at a refurbish company and they do not do board repairs i did more with electronics and loved to give it a go (not for them, i bought 3 broken laptops), and even if 1/3 worked i would be happy and i can practice a bit. so it might be they put on the wrong back cover on the left overs.... im sorry i might have fed you the wrong information if thats correct. it was not my intention (i do not like to redo things 15 times either)
                  any idea of what information you need ignoring the backplate, or can i get the the serial number from within the corrupt bios maybe ? so we can see what the actual model number was/is, i mean the sticker does not lie on the motherboard. i asume the backcover might be wrong
                  • Sparo
                    Quicksilver
                    • Jan 2022
                    • 2026
                    • M\A
                    Don't worry about the serial number You already posted the one on the cover that should be enough
                    The motherboard model number is actually printed directly on the motherboard itself. You just need to look closely around the board. Here's an example
                    >> Upgrade here <<
                    ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                    • wrinex
                      • Apr 2026
                      • 8
                      • Netherlands
                      Oh found it,, i did not expect it to be on the backside.... erm the one i see less often
                      its Crescent - 6050A3022501-MB-A01(A1)
                      you where spot on ! also ordered some of those probes see how that works. would save allot of time if it worked.
                      by the way now knowing the correct motherboard, should i try another bios ? maybe this one cant be saved anymore but i give it a few more tries for sure,. i dont like waste
                      • Sparo
                        Quicksilver
                        • Jan 2022
                        • 2026
                        • M\A
                        Yeah sure you can try again if you want, try these donor files from the internet
                        They are reported to be tested and working for that exact motherboard just like the ones I sent you earlier
                        I also attached a second combination since you mentioned the motherboard comes from a refurbishing company so might try it as well. Good Luck!
                        >> Upgrade here <<
                        ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                        • wrinex
                          • Apr 2026
                          • 8
                          • Netherlands
                          ill give it a try this weekend. thanks allot !
                          • Habble7
                            by Habble7
                            Suspected Cause:
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • Boardview and Schematic Bot
                            How To Check BIOS / EC firmware version for MSI notebook & Update it
                            Not sure how up to date this is....
                            How To Check BIOS/EC firmware version for MSI notebook?
                            Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
                            1. How to check BIOS/EC version by Help Desk?
                            1.1. Open MSI Help Desk.
                            Note: Help Desk is a built-in application for MSI notebooks. If you couldnโ€™t find this software in your Windows system, please download and install MSI Help Desk from product.
                            1.2. Click the [System Info].
                            1.3. BIOS and EC firmware version will display on screen.
                            03-27-2026, 01:12 PM
                          • DynaxSC
                            SPI chip BIOS dump for GIGABYTE X870E AORUS ELITE WIFI7
                            by DynaxSC
                            Hi, I look for an original BIOS dump from a GIGABYTE X870E AORUS ELITE WIFI7 motherboard. It must be a BIOS dump made from a real motherboard, not a stock Gigabyte BIOS download. There is apparently some major difference between a real BIOS image compared to a stock BIOS, as this motherboard does not start at all with a stock BIOS image. The board owner unfortunately did not make a backup from the original BIOS image, so now I have a bricked motherboard which does not want to start POST-ing at all. Although it powers on, but there are no debug codes showing, debug code display is dark, as well...
                            04-28-2026, 11:01 AM
                          • mikeybass
                            by mikeybass
                            04-23-2025, 04:30 PM
                          • haitham sharabati
                            by haitham sharabati
                            Hello engineers ๐Ÿ˜€,
                            Iโ€™m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as itโ€™s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.๐Ÿ˜
                            ๐Ÿ”ง Device Info:
                            - Model: HP 15-da2007ne
                            - Product Number: 8XF55EA#ABV
                            - Serial Number: CND0338P0D
                            - CPU: Intel Celeron N4000
                            ๐Ÿ’€ Problem:๐Ÿ˜…
                            - Device shows โ€œAdministrator Passwordโ€...
                            08-07-2025, 04:54 AM
