remove gpu from bios file for Gigabyte A7k1 laptop
  • PCWhoop
    • Jan 2026
    I have a Gigabyte A7 K1 laptop with a faulty dGPU.
    To troubleshoot, I disconnected the GPU core voltage (cut off GPU power rail). After doing this, the laptop powers on normally.
    However, the BIOS still detects the GPU as faulty. The fan ramps up to maximum speed, and after a short time, the laptop shuts down.
    I have attached:
    - Original BIOS dump
    - Motherboard pictures
    I am looking for:
    1. A modified BIOS with dGPU disabled, or
    2. Any guidance on how to bypass GPU detection in BIOS
    Any help would be greatly appreciated.
    Thank you
    • 23881
    please post the laptop serial number. Isn`t there a bios setting to switch to UMA only.
    • PCWhoop
      • Jan 2026
      no nothing on bios
      S/N:SN22031J001888
      • peste
        • 15170
        • ROMANIA
        Originally posted by PCWhoop
        no nothing on bios
        Don't post pictures unless asked...write with the keyboard..
        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
        It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • DynaxSC
          SPI chip BIOS dump for GIGABYTE X870E AORUS ELITE WIFI7
          by DynaxSC
          Hi, I look for an original BIOS dump from a GIGABYTE X870E AORUS ELITE WIFI7 motherboard. It must be a BIOS dump made from a real motherboard, not a stock Gigabyte BIOS download. There is apparently some major difference between a real BIOS image compared to a stock BIOS, as this motherboard does not start at all with a stock BIOS image. The board owner unfortunately did not make a backup from the original BIOS image, so now I have a bricked motherboard which does not want to start POST-ing at all. Although it powers on, but there are no debug codes showing, debug code display is dark, as well...
          04-28-2026, 11:01 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • tonybig10
          gigabyte Z390 Aorus pro wifi DUMP BIOS CHIP BIN FILE
          by tonybig10
          Hi is any one happened to have the dump bios file for Gigabyte Z390 Aorus pro wifi I need to flush the chip. one from the Gigabyte manufacturer site did not work THANK
          12-30-2025, 10:56 AM
