BIOS Dump for Lenovo Yoga Slim 7 15ILL9 (83HM) LNVNB161216
  • dragic98
    • Mar 2026
    Model: Lenovo Yoga Slim 7 15ILL9
    Machine Type Model: 83HM
    Motherboard ID: LNVNB161216
    TLDR: I would like to have the clean BIOS dump file for my laptop model.
    Issue: First, my speaker wasn't working/showing up, so I downloaded the recommended BIOS update (from Jan 4, 2026) on Lenovo Support for my laptop. This didn't fix the speaker issue after restarting, so then I shut it down and pressed the power button for 60 seconds to perform a reset. I'm guessing I somehow messed up the BIOS because now the laptop won't turn on even after trying the NOVO button on the bottom. I also extracted the BIOS update file (from Jan 4, 2026) from Lenovo Support, put it on a 16GB USB (formatted to FAT32 and Master Boot Record), then did this combo (plugged in USB, Hold Fn+R, plug in charger, press power button once). This caused the LED next to the charging port to blink orange on/off for about 15 seconds then turning into a constant white. Then in the first minute or so, the backlit keyboard would periodically turn on and off, each accompanied with some faint beeping/whirring I could hear when putting my ear near the keyboard. However, the sounds and keyboard lights then shut off for the remainder of the 15 minutes I waited (because I saw online/Gemini that during this time, the laptop is supposed to do some memory training if flashing worked). I would like to try flashing the clean BIOS dump file which is supposedly 16MB or 32MB and not the 8.61MB update file that is publicly listed. I am planning to buy a CH341A Programmer and WSON8 probe as suggested by Gemini to eventually flash this clean dump file onto my laptop via USB. Any help/input would be very, very appreciated and of course obtaining the clean BIOS dump file if possible. Thank you everyone!
  • Sparo
    Quicksilver
    • Jan 2022
    • 1954
    • M\A
    • Anime, Edge Computing, Football, Snooker
    [Issue...]
    Hi you have to post the machine's serial number with every request. Also post your BIOS backup to fix even if it's corrupted
    Take some time to read the Forum's rules > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
    Enjoying our forum? Help keep it running and unlock extra perks!
    >> Upgrade here <<
    • samirinfo
      Lenovo Yoga slim 7 14ITL05 Bios dump/Password remove
      by samirinfo
      Can I remove my bios dump?
      SN: LR0EJB0E
      Factory ID: CS20
      Lenovo Yoga 7 14ITL05
      Board: DALSBMBAG0 REV : G
      HELP PLZ
      post moved..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.....
      12-28-2025, 07:48 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Mariuspcb
      Bios Yoga Slim 7 ProX 14ARH7 - Type 82TL
      by Mariuspcb
      Hi!
      I need some help with a new bios for : Yoga Slim 7 ProX 14ARH7 - Type 82TL
      S/N PF4NF3YS
      See the backup bios attached.
      I would very much appreciate some help with this.
      Thank you!
      Kind regards...
      04-13-2026, 10:14 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • kinojk2
      ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
      by kinojk2
      Hi, Thanks for all you do here.
      I have attached my 16MB dump.
      EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
      EDIT:
      I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
      The clips are such a pain to use, soldering would be a great skill to have.
      Thanks for the advice in other threads!
      To answer my own question, I didn't...
      03-24-2026, 05:55 AM
