HP OMEN 16-wd0013dx bios
  • kjchatman
    • Dec 2012
    • 245
    • united states
    i have a customer's hp victus laptop that had an issue with charging but it would boot up with a charged battery but now it doesn't boot up but the power light comes on and the caplock blinks once then it loses power all together. i'm getting 2v instead of 3v on the power button and i suspect that the EC is corrupt. I need someone to extract the EC contents from the main bios
    • 24100
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • kjchatman
      • Dec 2012
      • 245
      • united states
      SN : CND3171LC1
      OMEN by HP Gaming Laptop 16-wd0013dx
      LA-M787P rev 2.0
      • m1ch43lzm
        • Mar 2019
        • 2330
        • Peru
        Try EC extracted from your BIOS, ENE KB9542
        • kjchatman
          • Dec 2012
          • 245
          • united states
          thank you very much. How do you use a 160 kb file? i'd like to backup the original contents but it only saved 128 kb of it
          • m1ch43lzm
            • Mar 2019
            • 2330
            • Peru
            Check on your programmer software if it has an option to manually select size, select 160KB
            • kjchatman
              • Dec 2012
              • 245
              • united states
              can you recommend a programmer software that works with a vertyanov clone that i can do that?
                • 24100
                Which clone is it the turkish one
                • kjchatman
                  • Dec 2012
                  • 245
                  • united states
                  it says micro-vision programmer rev. 4
                    • 24100
                    can you post a picture
                    • kjchatman
                      • Dec 2012
                      • 245
                      • united states
                      i got it from ioprogrammer.com
                      • kjchatman
                        • Dec 2012
                        • 245
                        • united states
                        if i replace the kb9542QG with a blank one then wouldn't it self heal? this is an hp and the bios has ec image?
                        • JoWed
                          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                          by JoWed
                          Hello Community,
                          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                          07-01-2025, 09:32 AM
                        • kenkaniff
                          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                          by kenkaniff
                          Product Name: HP Pro x360 Fortis 11-inch G9
                          System BIOS: U94 Ver.01.08.00 10/06/2023
                          Serial Number: 5CG31946F5
                          SKU Number: 85W05EC#AK8
                          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                          I needed to remove bios password...
                          10-01-2025, 04:32 AM
                        • bad0menz
                          HP Omen 16-wdxxxx Bricked After Successful(?) BIOS Flash
                          by bad0menz
                          I wanted to remove the BIOS password on my Omen 16, so I used a ch314a to flash a modified BIOS file. Based on readings, the chip seems to have been programmed correctly, however the computer won't POST or boot—no fan, and either the power button blinks 1 long 1 short, or the capslock blinks once before shutting off.
                          There shouldn't be any shorts or physical damage from what I can tell
                          This Omen probably has HP SureStart Gen4, a firmware-level security feature embedded in the BIOS, however I've been told that "just by flashing to the dedicated flash there should...
                          04-26-2026, 01:02 PM
                        • Dani Rahal
                          hp omen 17-cb0247ng bios
                          by Dani Rahal
                          Hi can some one help me plz
                          i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                          i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                          the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                          i have the orginal bios if some one can see what the problem or...
                          05-30-2025, 09:11 AM
                        • GGGGame
                          HP Omen 16-c0950nz DAG3KRMBCD0 REV:D No video after corrupted BIOS
                          by GGGGame
                          Board: DAG3KRMBCD0 REV: D
                          Model: HP Omen 16-c0950nz
                          Serial: 5CD151F4QW
                          CPU: AMD Ryzen 9 5900HX
                          GPU: Nvidia RTX 3070
                          BIOS chip: GigaDevice GD25LQ128C 1.8V 16MB
                          Problem: While using Ubuntu with a light program running, the screen suddenly went black. Fan speed was normal, keyboard LEDs were still on. After reboot, no video on internal or external display, not even at BIOS level.
                          What I tried:
                          Tested with single RAM sticks in both slots
                          Tried external monitor via HDMI
                          Performed IPA wash of the motherboard
                          Flashed official HP...
                          05-24-2026, 07:39 AM
