Alienware 17 R2 BIOS Recovery Help + BIOS Flash File Request
  • cepha03
    • Dec 2025
    Bought a cheap Alienware 17 R2 that doesn't POST. Once turned on, lights illuminate and goes through a continous boot loop of turning off and repeat. I've tried all the easy remedies (Replace RAM/Ctrl+Esc/Clear CMOS/ Replace CMOS/Formatting USB to FAT importing the .rcv file and holding End upon boot). Seems like the only solution now is to reflash the BIOS chip with a programmer. Problem is, there's two. I've provided pictures of both. I'm unable to discern which one I'm supposed to flash so any help would be greatly appreciated. Also, if anyone has it could I also have the BIOS flash file as I seemingly can't find it anywhere here.
    Check the photos for more info! TIA
ID:	3784554 Click image for larger version
  • peste
    • 15083
    • ROMANIA
    Click image for larger version  Name:	1000017325.jpg Views:	0 Size:	1,013.7 KB ID:	3784554 Click image for larger version  Name:	1000017326.jpg Views:	0 Size:	1.21 MB ID:	3784555
    post S/N, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    post them both..
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • pcwhiz24
      Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
      by pcwhiz24
      Model: Lenovo IdeaPad 3 14ADA05 81W0
      S/N: PF2BZS7D
      I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
      I already have a CH341A programmer...
      04-07-2025, 07:10 PM
    • abhorsen
      Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
      by abhorsen
      Hey guys,
      Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
      Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
      Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
      07-06-2023, 10:22 AM
