HP Error "FAR must be enabled before MPM can be locked"
  • quyet306
    • Oct 2014
    • 91
    • saigon
    Hello I have this error on my HP Elitebook 655 G10
    I tried many dump but FAR error still, i can't find anything information for this error
    Has anyone seen it before and what is solution for this error?
    • 23923
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • khaahk
      • Dec 2013
      • 901
      • Estonia
      Have you googled for solution?
      "FAR must be enabled"
      refers to a BIOS/firmware setting (likely "Firmware Active Recovery" or similar) on HP laptops required to lock the Manufacturing Programming Mode (MPM), often seen when replacing system boards or during maintenance. It typically involves enabling this feature within the HP BIOS settings (F10) under security or advanced options
      • danito
        • Jun 2016
        • 1651
        read post 2
        • quyet306
          • Oct 2014
          • 91
          • saigon
          Originally posted by danito
          read post 2
          thank you
          Serial number is 5CD2378J8F
          i can't find anything FAR in BIOS Setting
          • hoaca388
            Badcaps
            • Jan 2022
            • 12713
            Try
            If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
            Subscribe to support us. It only takes 1 minute:
            https://www.badcaps.net/settings/subscriptions
            • quyet306
              • Oct 2014
              • 91
              • saigon
              Originally posted by hoaca388
              Try
              thank you. but after enter DMI info and restart FAR Error is still sir
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • sushilachuthan
                APC UPS error P13
                by sushilachuthan
                one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                We replaced the SCR with new device,, but the device is not power on as expected.
                Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                09-26-2025, 09:00 AM
              • vickey_vip
                dell OptiPlex 3050 all in one bios error solution
                by vickey_vip
                Hi I need bios for dell OptiPlex 3050 all in one mb part is ipkbl-sr/35w.
                Old bios display is coming but giving following error
                (A7) FW downgrade - request mespilock fail upon starting
                After this error all in one again restart and again same error not booting
                I am attaching here old file
                Urgent help required because its server pc of someone
                Link of dell page here
                https://www.dell.com/support/home/en...SQT090/drivers...
                02-23-2024, 11:49 PM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • pkslowk
                Debug Card Error Code and Solution
                by pkslowk
                Sr. Motherboard Debug Error Code Solution
                1 Intel 845 E9 Bios Related Problem
                2 Intel 845 D4 CPU Socket Related problem
                3 Intel 845 37 Bios Related Problem
                4 Intel 845 7C Bios Related Problem
                5 Intel 945GCPE 34 Bios Related Problem
                6 Gigabyte 845 2 Ram Related Problem
                7 IBM Server A6 A7 Ram Mismatch Problem
                8 Asus 845 29 CPU Related Problem
                9 Lenovo I946 97 C-Mos Jumper related
                10 Gigabyte 845 A0 CPU Related Problem
                11 Asrock G31M-VS D7 Bios Related Problem
                12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                01-28-2021, 12:51 PM
