  • t1s50
    • Nov 2025
    • 7
    • Norway
    It's all said already
    Originally posted by cr4zychriss
    Hello everyone,[*]The Brick: Attempted to extract and flash a 64KB EC part from an old 1.04 file using dd and from the EFI shell flashed it with ifux64.efi .[*]The flash completed, but after an EC reset, the laptop went COMPLETELY DEAD (no power LED, no charge indicator, no fans, no POST). Later realised the initial 64KB extraction/flash was faulty and corrupted the EC boot sequence.
    You flashed the EC firmware with something you extracted somewhere which bricked the board
    The EC firmware resides INSIDE the EC chip and can't be flashed easily
    You need either
    - a preprogrammed EC- chip / IT5571e (see #15) to replace the EC chip or
    - a programmer that can program an IT5571e
    The GigaDevice GD25LQ80 is the graphics cards firmware.
    It is an 1.8V chip according to datasheet, you may have damaged it when reading / programming it as 3.3V chip.
    You didn't do anything with that chip when using ifux64, so basically there wasn't any need to fiddle with it.
    Flash the original content of this chip back, check thoroughly for proper programming since the chip may have been damaged.
    Flash your original backup for the bios firmware back to the 25Q128JVSQ
    • cr4zychriss
      Padawan
      • Nov 2025
      • 12
      You need either
      - i figured that out by myself when i bricked it
      - miss interpreted the diagram wrongfully and chatgpt dint help at all with this .
      Anyways not whats done is done… the viable questions that remain are:
      1. if i get a svod, would i be able to reprogram the on board ITE without desoldering it ?
      2. if that isnt an option, where can i buy a replacement ?
      3. The crap that i flashed in the GD chip has been erased (ive used 1.8V adapter and the chip is still good, can read/write to it, no issue), i di not have a backup of it, so how can i restore that one ?
      4. is the PCS EC from my attachment the right thing to flash to the ITE?
      if you would be kind enough to explain in detail what are my real recovery chances here ?
      i am willing to take it to a service but the people that ive already tried in the uk, said they do not have the specific firmware for this .
      Many thanks for your time and patience.
      • t1s50
        • Nov 2025
        • 7
        • Norway
        Too many variables to answer that.
        Probably
        Either you have a compatible programmer then you can find out yourself or you have a preprogrammed chip...
        • inck243
          Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
          by inck243
          Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
          The BIOS...
          07-25-2024, 09:17 AM
        • testaccgta
          Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
          by testaccgta
          Hi, everyone!
          I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
          I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
          09-01-2024, 08:24 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
        • thxd43
          Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
          by thxd43
          Hello, first of all, excuse me, I am using the translator, English is not my native language.
          I have a Lenovo ideapad 330S - 14IKB laptop.
          The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
          02-23-2023, 08:37 PM
        • TopPop
          Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
          by TopPop
          Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
          I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
          12-14-2025, 09:40 PM
