Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
This is a sticky topic.
  • m1ch43lzm
    • Mar 2019
    • 3566
    • Peru
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R tab in the main window
Name:	xgpro gd25lq128d otp.png
    Solution: Make sure you check the FLASH radio button on the Save dialog, under "Select buffer", that way only the FLASH region will be saved (which is the region we're interested in), and the backup will have the proper file size
    You have to change this option every time you press the Save button, as it resets to DEFAULT every time
Name:	xgpro save as.png
    For 64 Mbit (8MB) chips, the file size should be exactly 8388608 bytes
    For 128 Mbit (16MB) chips, the file size should be exactly 16777216 bytes
    For 256 Mbit (32MB) chips, the file size should be exactly 33554432 bytes
    For 512 Mbit (64MB) chips, the file size should be exactly 67108864 bytes
    If you already have a saved file of the "wrong" size, those extra bytes at the end can be safely trimmed with a hex editor, keeping in mind the correct file size of course
  • m1ch43lzm
    • Mar 2019
    • 3566
    • Peru
    Additional info: Xgpro 12.96 software also appends an additional -Configuration- with a copy of the STATUS registers at the end of the files when DEFAULT is selected at the save dialog
    Example:
    Click image for larger version  Name:	xgpro -configuration-.png Views:	0 Size:	13.6 KB ID:	3721907
    The above info still applies, select "FLASH" under "Select Buffer"
    Premium supporters get full download access and other benefits.
    • Winwares
      Winwares commented
      Editing a comment
      thanks for this info... really helped me
  • toannh92it
    • Oct 2021
    • 16
    • Viet Nam
    thanks, useful post for me, after updating xgecu to 12.96
    • to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
      by to5it0
      Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
      I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
      This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
      I have opened the laptop and identified the main BIOS chip...
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • EbrahimSiami
      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
      by EbrahimSiami
      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
      **What I have tried so far:**
      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
      07-02-2025, 02:31 PM
    • Adilson Silva
      Dell PowerEdge T110 server that stopped working after a stress test - bios request
      by Adilson Silva
      I'm working on a Dell PowerEdge T110 server that stopped working after a stress test. I need help recovering the VPD EEPROM (AT24C02).
      ― HISTORY ―
      I bought this server at a charity bazaar (Pequeno Cotolêngo, Brazil). I cleaned it up, installed Windows 10 LTSC, and tested it all day — heavy file transfers to 3 HDDs, driver installations, and finally added an external audio card to watch YouTube. At that point the machine shut down suddenly and never came back.
      ― SYMPTOMS ―
      • Power supply would not arm (no PS_ON signal)
      04-25-2026, 04:28 PM
