DELL PRO 14 PC14250
Try this file and give feedbackAttached FilesPremium supporters get full download access and other benefits.
Try this one and give feedbackAttached FilesPremium supporters get full download access and other benefits.
Hi there i have a Dell PC14250, suffix 8fc8, and bios locked, I've tried tools such as the 8fc8 patcher and flashing someone's blank bios to no avail.
Any chance someone can help?
ST: 4HVQNC4
attached is .bin backup of both u2501 + u2502 winbond flash chips
Thank you!Attached FilesPremium supporters get full download access and other benefits.
Hi, Both users who posted above, I guess... I tried to help, and I know what I patched isn't the PW
(more like built-in BIOS account descriptors, but nothing to lose anyway)
> https://www.badcaps.net/forum/troubl...07#post3884707
> https://www.badcaps.net/forum/troubl...54#post3891354Comment
I need help removing the password on a Dell Pro 14 PC14250
service tag: DP2VWC4 8FC8
243052-1Attached FilesPremium supporters get full download access and other benefits.
service tag: 29MX4D4
Try at your own risk and give feedback if working or not - https://www.badcaps.net/forum/troubl...nlock-all-dell
Pls remove admin pass
sn: G75SGB4
Try and feedback.Attached FilesPremium supporters get full download access and other benefits.
Hi, The 1B58 algorithm isn't released yet
You could Post your BIOS backups to see if someone can help you
Or try the method in comment #'72.1 > https://www.badcaps.net/forum/troubl...25#post3897825Comment
What about this one??
Dell 14 MC14250, 5D9F694-8FC8
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
I'm working on a Dell PowerEdge T110 server that stopped working after a stress test. I need help recovering the VPD EEPROM (AT24C02).
β HISTORY β
I bought this server at a charity bazaar (Pequeno CotolΓͺngo, Brazil). I cleaned it up, installed Windows 10 LTSC, and tested it all day β heavy file transfers to 3 HDDs, driver installations, and finally added an external audio card to watch YouTube. At that point the machine shut down suddenly and never came back.
β SYMPTOMS β
β’ Power supply would not arm (no PS_ON signal)...-
04-25-2026, 04:28 PM -
by TeslaI have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here... -
Dell Inspiron 15 3576(17841-1 VEGAS)
Dell Vostro 3478 (17841-1 VEGAS)
Boardview & Schematic...-
Channel: Schematics and Boardviews
06-30-2026, 02:12 PM -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
- Loading...
