BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
  • legendkray
    • Jul 2025
    • 7
    I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some locked bios options and edited bios file and flashed again, it worked (it didn’t unlocked anything tho) but display and right side USB port was not working. I also updated my ME driver in windows thinking it might fix the right side usb port but it didn’t so afterwards, I opened back of my laptop to check whethet I didn’t plugged cables well or did a mistake etc. and closed the back after checking and this time it started to launch yet no display (even no external display image) and fans were spinning on full speed with keyboard led on and afterwards I tried to flash to stock BIOS again (thought it might fix it again somehow) and it was still the same issue then I reflashed EC firmware again and this time after trying so many things it justs opens and shuts down after 2 second. I really do not know what caused this issue.
    However, I thought requesting help here might help if its related to BIOS maybe I am not sure.
    CPU is 14900HX
    Motherboard says its GM6IX7A-XN11 v1.1 (although some parts its written GM5IX7A)
    EC firmware version: 1.16.00
    BIOS: N.1.07OPC01
    I have attached the BIOS from the Vendor and their notes. I would be happy if anyone can help regarding what to do. I do not know if its caused by EC, BIOS or because I updated the ME firmware otherthan some version than provided by the vendor’s driver files.
    Thank you in advance and waiting for your responses
  • peste
    • Dec 2016
    • 12652
    • ROMANIA
    CPU is 14900HX
    BIOS: N.1.07OPC01
    post full name and model,...
    • legendkray
      • Jul 2025
      • 7
      Hello, I did it’s OriginPC EON15 SL the laptop I have
      • legendkray
        • Jul 2025
        • 7
        I think I need to clean the ME but I cannot find 16.1.30.2330 Consumer H RGN anywhere. Does anyone has it and can help me with this BIOS?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11645
          Your bios has clean ME area.
Name:	2025-07-06 06_04_59-Settings.png
          • legendkray
            • Jul 2025
            • 7
            thank you for taking a look at it, I appreciate it. My laptop shuts down after 1-2 second, I still can’t figure out why exactly. What can you suggest?
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Bloodhoundje
              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
              by Bloodhoundje
              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
              I have desoldered the bios chip (GigaDevice...
              03-16-2024, 03:12 PM
            • nosfay
              Intel NUC NUC10i5FNK - Bios & firmware request
              by nosfay
              I need clean bios & firmware for an intel that doesn't boot.
              Model : NUC10FNK
              Product code : BXNUC10i5FNKN2
              Here is my dump, but i dont know which one is the bios or firmware as there is 2 different chip, MX25L25673G and MX25V8035F so I've dumped both.
              Thanks for your help !
              EDIT: you can find official bios and firmware here https://www.asus.com/supportonly/nuc...helpdesk_bios/...
              11-01-2024, 08:10 AM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
