Gigabyte RC55 G5 GE
  • snar
    • Feb 2018
    • 74
    • philippines
    Gigabyte RC55 G5 GE
    Hi Everyone, can someone please fix my bios the problem is no display. all voltage are present. il attach the original bios.
    model: Gigabyte RC55 G5 GE
    Model no:AX211NGW
    sn: SN22471J001709
    board model:6-71-NP5K0-D02A
    • 21196
    Model no:AX211NGW
    sn: SN22471J001709
    Model no:AX211NGW is the model of the wifi card..
    You can get a virgin bios image from gigabyte support -> https://www.gigabyte.com/Laptop/G5--...ort#support-dl make sure you choose the GE model.
    The bios file name is NPx0PNx.04 ,it`s 32,768KB
    Copy the DMI from your backup to the new bios ,these are the offsets 10CC000 - 10CC07F and 10CD000 - 10CD03F
    • snar
      • Feb 2018
      • 74
      • philippines
      THank you sir. Sir do i need to copy the old DMI? or is it ok to flash NPx0PNx.04 directly? sorry sir i am newbie to this bios editing. I read your thread sir. the title is " Copy DMI info easily with Hex editing software and Macro script" i am very confuse how to run CopyDMI.mps of the step 6 in the instruction.
        • 21196
        That`s the wrong thing to use. I`ve done it for you.
        • snar
          • Feb 2018
          • 74
          • philippines
          Thank you sir. i let you know if this bios is working.
          • snar
            • Feb 2018
            • 74
            • philippines
            sir i already flash the bios but unfortunately still no display. i think this is not a bios issue. once again thank you sir. more power.
            • cekcons
              Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
              by cekcons
              Gigabyte G1 Assasain motherboard Bios IC model needed !
              Bios ic fried and I cant read the model on top.
              Thanks !
              07-16-2025, 01:22 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Caimano
              Need to copy DMI info for HP ProBook 650 G2 Bios
              by Caimano
              UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
              Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
              01-03-2024, 05:19 AM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
