HP 17 cn0104nz Power on password
  • DrSeronja
    • Jan 2021
    • 7
    • Bosnia & Herzegovina
    Hello, i have working hp 17-cn0104nz laptop with administration power on password, and i cannot find clean bios .i made dump of bios, so can you please help me to unlock my dump. Thanks in advance... here is dump
    Model : HP 17-cn0104nz
    SN : 5CG1301QX4
    ProductID 4Q689EA#UUZ
    MB Model : 6050A3261701-MB-A01 (A1) 17N-6L-GML
  • peste
    • Dec 2016
    • 12806
    • ROMANIA
    SN : 5CG1301QX4
    bios extracted from HP website update for HP Laptop 17-cn0104nz (4Q689EA)
    DMI 3C7000 - 3C913F​
    • DrSeronja
      • Jan 2021
      • 7
      Your bin file is 16mb, mine is 8mb. Here is picture of chip that i made dump from.
        • 20898
        Other DMI 3C5000 - 3C503F
          • 20898
          I don`t know if it`s supposed to be 8 or 16MB but someone has been messing around with the DMI i think... see the pictures.
          Edit: Feature byte should be 3K6b7K7P7WaBapaqasawbCbhcbdUdpdqfPm9n3n4.2N
          • DrSeronja
            • Jan 2021
            • 7
            This is first time for me to read this type of chip (on this laptop and even general , i used ezp2023+ with 1.8v adapter. What did you think, maybe programer does not reading properly.
              • 20898
              Try this bios. Yours was corrupted in parts but i don`t think that was the reason for the DMI being like it was. Slow your programmer speed down to 6Mhz for reading and writing.
                • 20898
                DMI 3C7000 - 3C913F
                I know why you posted that bios. When we extract the latest bios version F.49 Rev.A from sp158904exe it extracts 087C9 and only that.But, that bios has TGP chipset support, Tiger Lake so it can`t be that bios as the laptop has a Celeron N4020
                Specifications https://support.hp.com/gb-en/document/c07732402 The CPU is N4020 ,Gemini Lake refresh .
                Bios version F.31 Rev.A can be extracted with AMIUCP, there are three 16MB AMI bios images and two Insyde bios images, one is 8MB the other 16MB. The Insyde 8MB image has Gemini Lake chipset support (GLK) the other 16MB image is Jasper Lake
                Why the hell HP can`t just post a single bios on their support page per model number is beyond me. F18 is for AMD machines
                • DrSeronja
                  • Jan 2021
                  • 7
                  Thanks for help, i will test it today and reply.
                  • DrSeronja
                    • Jan 2021
                    • 7
                    Something is definitely wrong with my programmer. The 8MB file you sent throws an error during writing, and when I tried to restore the original dump, it gives the same error. I'll try using my friend's programmer — he has a better one, so it's possible that it will recognize it as 16MB on his.
                      SMDFlea commented
                      Editing a comment
                      its an 8MB chip and should be recognised as so. If there are any errors with your friends programmer replace the chip.
                  • Nopslide
                    by Nopslide
                    04-01-2024, 04:27 PM
                  • Buzzfuzz2k
                    Bios password removal on a Unowhy dump
                    by Buzzfuzz2k
                    Hi Everyone,
                    I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                    The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                    the Computer is a Unowhy small pc
                    N° UYM6524702229
                    After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                    My first attempt was to get the bios dump from windows...
                    11-13-2023, 07:37 AM
                  • outsider
                    Panasonic FZ-G1 MK5 - BIOS password returning
                    by outsider
                    Hello
                    I removed the BIOS password thanks to the help of one of the friends of this forum.
                    https://www.badcaps.net/forum/troubl...61#post3637661
                    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                    06-17-2025, 12:51 AM
                  • blionb
                    Need help resetting BIOS Password on a new to me HP ZBook Power G9
                    by blionb
                    Hi All,
                    I have gone through all the postings about what I could find for the HP ZBook Power G9 to reset the BIOS password with help from RC Unlocker. I bought this unit from eBay and while it's a recent build (August 2023), it has definitely seen much better days (bent case, beat up top cover and a messed up RTX A2000 - somebody definitely went to town on it).
                    HP tells me that they will charge me nearly the price of the unit (for the motherboard) if they find so much as a BIOS password set on it despite the fact that the unit boots without entering any password.
                    02-04-2024, 09:03 AM
