Bios for Insys GW1-W149 or GW1-W148
  • lulox
    • Dec 2013
    • 6
    • Portugal
    Please someone have clean bios for this models?
    Or can clean the ME on this files please
    • 21620
    Type the laptop serial number, full name and model, motherboard model, etc.
    read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
    • lulox
      • Dec 2013
      • 6
      • Portugal
      Sorry i forgot
      Brand: Insys
      Model: GW1-W149
      Serial: GW1W1490129288
      Motherboard: EM_IC218_376B_V2.0
      • boneco69
        • Jul 2010
        • 7
        Hello. I have similar problem with one of these boards - I have one school laptop that i need to fix that have the BIOS "corrupted" - do not even boot to BIOS it self. Changing the UEFI from another (damaged) board and the system boots to UEFI but refuses "to see" (it blocks the access to) the SSD. NOTE - Can boot to USB Linux in it but the SATA SSD wont show up in kernel. Of course cannot boot to Windows because i do not have the SSD functional.
        Now,t his is clearly some ME or the security module (CUCo) inside that is blocking or not enabling SATA interface. Using UEFITool we can see exactly that module in the flash file.
        I am trying to detect where the serial number is stored so i can copy (or write it) to the known good boot UEFI. I have contacted the importer asking them if they can send me an original file to flash it but they refuse - they want to sell another motherboard... so is not an option. The motherboard is good...
        I do not think that cleaning the ME region will resolve the issue. There are some scripts that disable ME - i am reading them and try to see if i can.
        Trying also to clean NVRAM, because it can cause freezing in some laptops after the BIOS could even switch on the graphics.
        Comparing the EC zone and the BIOS (code) modules between two files (dumped both bios chip) they are equal - so the problem is in the "data" segments (NVRAM) not the code (but it is buggy because of this lockup).
        The UEFITool can extract all modules without any problem in any of this two dumps, so the "corruption" is not bad flashing or bad flash sector, or else there were errors.
        NOTE/IMPORTANT: I do not want to disable nor remove the CUCo module because it is needed to be there - so we can block the computer if conditions apply. But i want to know how to fix this UEFI so i can repair future cases - those are school laptops and if we can save some money to the organization, better.
          SMDFlea commented
          Editing a comment
          post your backup and serial number, let`s see if it can be fixed
      • boneco69
        • Jul 2010
        • 7
        Ok, so lets see what you can make.
        Attached is the "BAD" flash with its serial number in its name (GW1W1490006778), and
        one that is working ok in its respective motherboard (GW1W149001227). As i wrote before, if i solder the "OK" chip in de "BAD" motherboard, the system works aside the SATA port not "detected".
        Note: I uploaded ZIP file because i can not upload bin. The "_OK" and "_BAD" part, of course, are not in the Serial Number...
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
