Lenovo V155-15API good bios request
  • AppleLover123
    Mr.Bombastic
    • Dec 2023
    • 61
    Hello guys,
    ive got a Lenovo here that wont display.
    On Google and here on badcaps i didnt found a good bios dump/file so plz if anyone has it.
    I tried disable the onboard ram in bios via SPD removal Tool 1.6. But with the new BIOS it didnt work either.
    My dump is in the attachements
    Please help!
    Last edited by AppleLover123; 05-01-2025, 06:40 AM. Reason: Forgot to attach the original dump
  • peste
    • 12600
    • ROMANIA
    Originally posted by AppleLover123
    Hello guys,
    Please help!
    post S/N, full name and model, motherboard model, TYPE,etc.
    • AppleLover123
      Mr.Bombastic
      • Dec 2023
      • 61
      Lenovo V155-15API
      Model Name:81V5
      Serial Nr: PF2125LC
      MTM: 81V50004GE
      Factory ID: JVHFC1
      MO: PF9XB9B23174
      Motherboard Model: FG542 FG543 FG742 NM-C101
      Rev: 1.0
      2019 - 05 - 07
      • AppleLover123
        Mr.Bombastic
        • Dec 2023
        • 61
        I found a good bios on a discord server but nothing changes when i try it.
        What i didn't mention is that the current at some point isnt changing anymore when i let it run for 2-3 mins.
        That makes me think maybe the onboard ram is faulty... Is there any way to disable it thenclike removing resistors?
        • peste
          • 12600
          • ROMANIA
          bios extracted from Lenovo website update for L340-15API, L340-17API, L340-15API Touch, V155-15API
          DMI 2C9000 - 2CAFFF​
          • AppleLover123
            Mr.Bombastic
            • Dec 2023
            • 61
            (Repost)
            Hello guys,
            i have this laptop here that wont display.
            First thing i did was checking voltages and all are Present.
            After that i tried another ram sticks but they didnt change anything as well.
            Then i tried programming the bios with two different bios files but nothing changed (i used the ch341a without the 1.8v Adapter but I was able to read/write the chip).
            Now i thought it could be a ram issue.
            I flashed a bios with onboard ram disabled (dump attached) and i moved the resistors on the right Place like it's Show in the picture (attached).
            But nothing changed.
            The last thing i did is desoldering the ram Chips from the motherboard but the only thing changed is the current draw that went from 800-900milliamps to 370milliamps.
            What could be the fault here?
            Does it has anything to do with the bios chip? (W25Q64FW 1.8V)
            I have attached a Bios from Lenovos Website that was given to me in a Bios Request...Can someone disable the onboard ram in that bios for me?​
              • 20656
              Try the ram patcher script - https://www.badcaps.net/forum/troubl...20#post3232220
              • AppleLover123
                Mr.Bombastic
                • Dec 2023
                • 61
                Tried it and flashed the bios file... Now the current draw is 900-800milliamps again but still no picture.
                I forgot to mention that ive got the Ryzen 3 3200u model. Maybe its a difference between the ryzen 5 and 3.
                I found new Symptoms like it wont start or shut down when i press the power button.
                It only powers on when i plug the charger.
                It charges fine with about 900milliamps and runs over the battery when powered and charger disconected.
                After a while the current draw goes down to 600 milliamps.
                Voltage on ram module is present.
                Nice tool what you developed. Maybe it will work when i have a dump from a ryzen 3 model.
                • AppleLover123
                  Mr.Bombastic
                  • Dec 2023
                  • 61
                  Hey guys,
                  i did make a few Threads now but I wanted to make it clear.
                  I need a new BIOS Image for this Laptop:
                  Lenovo V155-15API
                  Model Name:81V5
                  Serial Nr: PF2125LC
                  MTM: 81V50004GE
                  Factory ID: JVHFC1
                  MO: PF9XB9B23174
                  Rev: 1.0
                  2019 - 05 - 07
                  Ryzen 3 3200U Model
                  I moved the resistors on the right Place.
                  The Laptop had faulty onboard ram modules and i tried disableing the ram with SPD removal tool 1.6 and RAM patcher from this forum.
                  As it didnt post i scrolled to the entries of the ram Modules in Bios and there were parts that didnt get Set to zero so i Set them to zero and flashed it again (tried 2 times) Laptop wont Post and isnt reacting to the Power Button to turn in off.
                  Can someone disable the onboard ram in the new BIOS Image then?
                  Without the Bios Chip it also turns on but drawing 400 mamps instead of 540 mamps.
                  Also i forgot to mentioned that with the image from Lenovos site i tried the same and didnt work either but the current draw is about 800-900mamps.​
                    SMDFlea commented
                    Editing a comment
                    Thread merged with previous request topic..
                • AppleLover123
                  Mr.Bombastic
                  • Dec 2023
                  • 61
                  No one???
                    • 20656
                    Hey guys,
                    Both threads merged. I think you are beating the dead horse with this ,it`s a hardware problem in my opinion.
                    • Wahaz
                      by Wahaz
                      10-30-2023, 08:42 PM
                    • mikosek7
                      Request for a good bios file for Lenovo Thincentre v520s
                      by mikosek7
                      Good morning!
                      Can I ask for a good bios .bin for Lenovo Thincentre v520s ?
                      Mainboard IB250MH, bios (Windbond25q64jsiq). Windows10 update corrupted the bios. Thank you for your help.
                      04-06-2024, 10:56 AM
                    • HammyCheesy
                      Lenovo ThinkStation P720 BIOS Request
                      by HammyCheesy
                      Hello all,
                      I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                      When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                      Type: 30BB
                      Model Number: S03600
                      S/N: MJ07N68C
                      Things I have tried:
                      1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                      2. Attempted to boot with just a single CPU...
                      04-11-2025, 01:02 AM
                    • grimacelord
                      by grimacelord
                      Hello there.
                      History:
                      03-15-2023, 03:29 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
