BIOS request MSI GE76 Raider
  • rollerclp
    • Jul 2024
    • 7
    Please, I need a BIOS for the MSI GE76 Raider
    Model 11UH-067AU-SG91198K32GXXDX10MA
    S/N:K2105N0086424
    Thank you so much
  • hoaca388
    Badcaps
    • Jan 2022
    • 11717
    S/N:K2105N0086424
    Thank you so much
    Wrong chip. Look for the chip with the number 256 on its back.
    GE76 Raider 11UH
    • rollerclp
      • Jul 2024
      • 7
      GE76 Raider 11UH
      You are completely right, attached the correct bios now.
      The one you sent is not working, it has changed the behavior, as with the original one the keyboard light was staying on as soon as powered up, with the one you sent it's blinking a few times and then stays on.
      Thank you so much
      • hoaca388
        Badcaps
        • Jan 2022
        • 11717
        Thank you so much
        I'm afraid you'll have to check the hardware.
        https://www.msi.com/Laptop/GE76-Raid...76-Raider-11UH
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • kingiii
          need help for bios MSI GE76 Raider 11UE
          by kingiii
          I think the bios has problem, 3v,5v and 1.8v all present, but no CPU voltage... Anyway, tried to flash bios, but the adapter dropped during reading and always with reading error afterwards.
          Here is the original from what I could read from the chip and model number is GE76 Raider 11UE
          sn : k2111n0090771
          Please help to repair bios.
          06-21-2025, 06:02 PM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
