Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
This topic has been answered.
  • pcwhiz24
    • Apr 2025
    • 17
    Model: Lenovo IdeaPad 3 14ADA05 81W0
    S/N: PF2BZS7D
    I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
    I already have a CH341A programmer on the way from Amazon that will arrive tomorrow but in the meantime, I want to try the FN+R recovery feature these all come with. I need the .Bin file of the original BIOS to put on my USB to revert it back. I'm an IT guy with 16 years of experience repairing laptops and such, but never used a CH341 before so it'll be a learning experience for me.
  • Answer selected by pcwhiz24 at 04-09-2025, 11:28 AM.
    SMDFlea
    • 22021
    Originally posted by pcwhiz24
    I'm so new to this lol. I figured it out, I attached the .zip with the dump file inside.
    Heres your new bios.
    • Bios Cracker
      • Oct 2024
      • 322
      • India
      S/N: PF2BZS7D
      After you get your CH341A programmer. Attach the original dump file, also before creating a new thread always search for the model you might find some already existing thread.
      • pcwhiz24
        • Apr 2025
        • 17
        How do I find the original dump file?
        • pcwhiz24
          • Apr 2025
          • 17
          The BIOS chip on it is a Winbond 25Q64JWSIQ. How do I get a dump file once I connect the CH341A?
        • pcwhiz24
          • Apr 2025
          • 17
          I pressed read IC on NeoProgrammer and saved the dump file but it's not letting me attach it here as .bin or .hex? What do I do now?
          • pcwhiz24
            • Apr 2025
            • 17
            • Bios Cracker
              • Oct 2024
              • 322
              • India
              Try and update
                • 22021
                Try and update
                Wrong bios posted, thats an intel bios, the IdeaPad 3 14ADA05 81W0 is AMD. Your bios has been removed.
                • Bios Cracker
                  • Oct 2024
                  • 322
                  • India
                  Thanks for correcting me.
                    • 22021
                    • pcwhiz24
                      • Apr 2025
                      • 17
                      Thank you! I took the BIOS file and flashed it which brought the laptop back successfully!
                      • Fr33man
                        BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                        by Fr33man
                        I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                        *Novo button power on
                        *Disconnected internal battery...
                        09-23-2024, 01:16 PM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • shan109
                        Lenovo LOQ 15 APH8 (7840H, 4060) BIOS chips not detected
                        by shan109
                        Problem: Soft Bricked Laptop, Lenovo LOQ 15(Geekpro G5000) 7840H, 4060
                        Background: After adjusting the Advanced BIOS options (Fn+R+N) and accidentally changing settings about RAM & Graphics, pressed F10 (Save & Exit), then Blank(Blank) screen, led power lights on - soft bricked occured.
                        Goal:To reset the BIOS Chip/s to be able to boot back to the machine
                        Attempted:
                        I tried to dump and reflash a BIOS file with CH431A clip on:
                        winbond
                        25Q16JWIQ 2309 6222 DGA400ZX
                        winbond
                        25R256JWEQ 2239 6236 M0022
                        10-31-2023, 09:52 PM
                      • David Gee
                        Bios Request HP 17-CN0023DX
                        by David Gee
                        I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
                        I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
                        05-03-2025, 09:58 AM
                      • SGVsbG8sIHdvcmxkIQ
                        Issue wtih [crisis] BIOS recovery
                        by SGVsbG8sIHdvcmxkIQ
                        BIOS update bricked my laptop - after restart the was a prompt to Proceed with ROM flash or Abort. None of 2 options worked - upon restart the same prompt shown.
                        I downloaded [BIOS update].exe file from Lenovo Support > extracted [firmware descriptor].fd file > renamed it to [correct crisis file name].bin.
                        With crisis file on USB drive the Proceed with ROM option launches recovery - after displaying the current and the new BIOS version, the process terminated immediately with validation error:
                        Not allow flash. Boot Guard version verification...
                        04-28-2024, 03:43 PM
