Need bios Lenovo Yoga 7 16iml9 NB6380E_MB_V3
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by AYsysHello dear forum members,
I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
Nothing was flashed here — the BIOS was only backed up.
I created the backup using a CH341A Black programmer and NeoProgrammer....-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
by beogeekI've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
Attached is the bios dump in the state I received it...-
- Loading...
