Acer Swift SF514-55TA Bios
  • cyngo
    • Jun 2015
    • 221
    • Indonesia
    Please help, laptop no display, Power button work, lights up briefly
    Code board NB2629_PCB_MB_V3
    SN:NXA6SSN0040470B4BC2N00
    SNID : 047046268223
    Thanks in advance
    Original bios
  • cyngo
    • Jun 2015
    • 221
    • Indonesia
    can someone help?​
    • RCCBUBC
      • Sep 2025
      • 15
      • CANADA
      Need help with the bios files. Laptop fail to post after turning on.
      Acer SF514-55TA-77P4 S/N: NXA6SAA005109090C22N00
      Thanks,
      • danito
        • Jun 2016
        • 1848
        • N/A
        Thanks,
        read again. is FF FF
          • 24922
          look again mate, the first 1MB is thunderbolt firmware , the rest is FF`s
          • Philou0023
            • Aug 2026
            • 10
            • France
            • cinema, vtt, drone
            I am looking for a clean EC dump (1MB / 8Mb) for my laptop. Unfortunately, I erased the original chip by mistake without making a proper backup.
            Here are the exact specifications of my laptop:
            • Laptop Model: Acer Swift 5 SF514-55TA
            • Motherboard Model: NB2629_PCB_MB_V3
            • EC Chip: Winbond W25Q80DV (8M-bit / 1MB)
            If anyone has a working dump for this specific board, please share it.
            Thank you very much for your help!
              • 24922
              Thread merged. Please read https://www.badcaps.net/forum/troubl...before-posting and post the laptop serial number
              • Philou0023
                • Aug 2026
                • 10
                • France
                Hello, I am French and my English is a bit rough.
                Thank you for your reply SMD FLEA. As suggested on your website, I tried to fix my BIOS issue on my own with my XM25QH128A chip. Unfortunately, I can no longer make a backup because I completely erased it using NeoProgrammer. I thought the BIOS file from the Acer website would be enough, but after researching on several sites, I learned that the BIOS must contain the ME region, the serial number, and other information that I unfortunately deleted during my first attempt (I clicked "Erase" instead of reading and saving it).
                I cannot solve this without your help. :-( :-( What exactly do I need to do so you can kindly help me get a working file that I can flash onto my corrupted BIOS?
                Laptop model: Acer Swift 5 SF514-55TA
                Motherboard model: NB2629_PCB_MB_V3
                Chip: XMC XM25QH128A
                Serial Number (SNID / S/N): NXA6SEF00304706E6A2N00
                • Philou0023
                  • Aug 2026
                  • 10
                  • France
                  Update with my exact laptop specs for rebuild:
                  • Laptop Model: Acer Swift 5 SF514-55TA-53TH
                  • Product Number: NX.A6SEF.003
                  • Serial Number (S/N): NXA6SEF00304706E6A2N00
                  • Motherboard: NB2629_PCB_MB_V3
                  • CPU: Intel Core i5-1135G7 (Tiger Lake)
                  • BIOS Chip: XMC XM25QH128A (16MB)
                  Unfortunately, my original dump is completely lost (accidental erase). Please help me provide a Working Clean ME BIOS dump matching this configuration. Thank you so much!
                    • 24922
                    Try this bios.
                    • Philou0023
                      • Aug 2026
                      • 10
                      • France
                      Thank you so much, SMDFlea! As soon as I can download it (for now, the website is still asking me to pay to access the file), I will immediately try the file you kindly sent me. I will come back here to let you know if it works. Thank you for this incredibly valuable help!!
                      • Philou0023
                        • Aug 2026
                        • 10
                        • France
                        Thank you for the BIOS file, SMDfléa. However, the computer is still blinking 3 or 4 times in blue, and then... nothing, it still won't boot. Is it possible that the issue is coming from the ITE chip, and could it be reprogrammed? Where could I find a firmware/dump for it? Thank you for your help!
                        • Philou0023
                          • Aug 2026
                          • 10
                          • France
                          Thank you for the BIOS file, SMDfléa. I flashed it successfully, but the issue remains exactly the same: the computer still blinks 3 or 4 times in blue and won't boot.
                          I have checked the voltage rails under power:
                          • The two 1R0 coils are getting 3.3V and 5.0V (perfectly stable).
                          • The R22 coils (CPU VCore) stay at 0V.
                          • Resistance to ground on the R22 coils is 32.5 Ohms (so no short circuit on the CPU line).
                          The board seems stuck just before enabling the CPU power sequence. Could it be an issue with the ME region or a bad communication with this specific BIOS dump? Or do you think the ITE IT5571VG-128 chip itself is dead?
                          • Philou0023
                            Philou0023 commented
                            Editing a comment
                            I programmed the BIOS chip directly on the board using a SOIC8 clip (the chip was not desoldered
                        • Philou0023
                          • Aug 2026
                          • 10
                          • France
                          Should I move this post to the hardware/electronics repair section now, since we seem to be heading toward an electronic component issue? Or is it better to keep the discussion here? Thank you for your guidance!
                          • peste
                            peste commented
                            Editing a comment
                            yes, move the discussion to the main forum if you no longer need the bios...
