HP 15-ec0037UR DA0G3HMB6D0 (Rev: D) BIOS Request
  • Alex Telt
    • Jan 2025
    • Україна
    Thank you in advance.
    Unit Powers on, fans rung at full RPM, no post or display. I suspect corrupted bios.
    Model: Model: HP Pavilion Gaming Laptop Model: 15-ec0037UR
    Motherboard: DDA0G3HMB6D0 (Rev: D)
    S/N: 5CD942D5S3
    ProdID: 8UC43EA#ACB
  • shiyab
    • Sep 2023
    • 1587
    • india
    S/N: 5CD942D5S3
    ProdID: 8UC43EA#ACB
    hi try
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • FalconPunch
      Surface Pro X 1876 Bios corrupted
      by FalconPunch
      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
      08-09-2025, 03:56 AM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
