GUIDE TO USE DELL PFS EXTRACTOR or other extractors from BiosUtilities (my way)
  • volinakis
    • Jan 2021
    • 2875
    • N/A
    1. Download BIOSUtilities (thanks to platomav) and move folder "BiosUtilities" to Desktop
    https://github.com/platomav/BIOSUtilities
    2. Install python 3.11.0 or higher (both versions for 32bit and 64bit)
    3. Download Dell bios update from Dell site (in my example bios update for Dell Latitude 3420) and move it to "BiosUtilities" from Desktop.
    4. RENAME update exe WHITOUT SPACES AND DOTS! In my example "Latitude_3420_Latitude_3520_1.37.0.exe" to "Latitude_3420_Latitude_3520_1_37_0.exe"
    5. Open cmd as admin and go to folder "BiosUtilities" from Desktop. For win10 win11 drag&drop "Dell_PFS_Extract.py" [space] "Latitude_3420_Latitude_3520_1_37_0.exe" and hit Enter. (for win7 use copy/paste)
    6. For ALIENWARE use "Insyde_IFD_Extract.py", is not AMI bios but Insyde!
    Click image for larger version  Name:	1.png Views:	0 Size:	82.1 KB ID:	3340740 Click image for larger version  Name:	2.png Views:	0 Size:	85.5 KB ID:	3340741 Click image for larger version  Name:	3.png Views:	0 Size:	9.9 KB ID:	3340742
  • pcguy
    • Nov 2012
    • 3
    I have bricked Dell XPS8500 I downloaded the A14.exe self extracting flash uitl from dell and tried the above method using command line in Windows10 and the above screenshot is the result. The error is
    Traceback (most recent call last):
    File "D:\_Drive_E\Downloads\BIOSUtilities-main\biosutilities\dell_pfs_extract.py", line 20, in <module>
    from biosutilities.common.checksums import checksum_8_xor
    ModuleNotFoundError: No module named 'biosutilities'
    D:\_Drive_E\Downloads\BIOSUtilities-main\biosutilities>
    ​Anyone have an idea what I am doing wrong?
      • 22236
      It isn`t a PFS Image so it won`t work.
      Run the exe and wait until it fails, leave the window open, don`t choose Quit.
      Go to C:\Users\YourName\AppData\Local\Temp
      In the Temp folder will be a folder with a name similar to _F7BA.tmp .Go into that folder, you should find an A12.cap file.
      Copy that file somewhere else, then you can Quit the Updater. Open that cap file with a hex editor, delete the CAPsule header 0 - FFF (Length 1000) and save. What you have now is a 2,560KB update, it isn`t a full bios image.​
      • pcguy
        • Nov 2012
        • 3
        Really appreciate the quick response. Did that. The resulting file is, 2,560KB and the first line starts with $TAG
          • 22236
          If you want your bios fixing post your request in this thread https://www.badcaps.net/forum/troubl...os-dump-needed ,make a backup and post it along with your service tag, or make a backup and try the bios at post #2
          • volinakis
            • Jan 2021
            • 2875
            • N/A
            it's only Bios_Region and it has 2621440 bytes. Post your bios backup where SMDFlea told you to see what ME Fw you need to build new bios.
            • jaglion19
              • Oct 2017
              • 111
              • TURKEY
              This is a BIOS exe file belonging to a Dell E7440. I couldn't open it with InnoExtractor, UniExtractor, 7Zip, WinRar, ResurceHacker, or any other program or Python file. When I double-click it, nothing comes up. If it does, I can extract the dump file from the Temp folder. How can I open it? Can you help me?
              • m1ch43lzm
                • Mar 2019
                • 1099
                • Peru
                It's an issue with the dependencies of the biosutilities package
                What worked for me was:
                1.
                Code:
                python -m pip install pefile==2023.2.7 dissect.util==3.20
                2. Download the required utilities separately (7z, UEFIFind, UEFIExtract, TianoCompress, big_script_tool.py and place them in "external" folder, inside the biosutilites folder
                Like this for example:
                C:\bios\BIOSUtilities-main\biosutilities\external\
                Code:
                C:\bios\BIOSUtilities-main\biosutilities\external>dir /b
                7-zip.dll
                7-zip32.dll
                7z.dll
                7z.exe
                7z.sfx
                7zCon.sfx
                7zFM.exe
                7zG.exe
                big_script_tool.py
                TianoCompress.exe
                UEFIExtract.exe
                UEFIFind.exe
                3. This step is important, it didn't work for me until i did this, you have to scroll down the instructions until you get to the packages section for this command, run it from the BIOSUtilities-main directory:
                Code:
                python -m pip install --upgrade biosutilities[pefile,lznt1]
                Code:
                C:\bios\BIOSUtilities-main>python -m pip install --upgrade biosutilities[pefile,lznt1]
                4. Create the output folder, i used "out", inside the BIOSUtilities-main folder
                C:\bios\BIOSUtilities-main\out\
                5. Copy your bios update E7440A28.exe to the BIOSUtilities-main folder and run the following command (in command prompt), it will ask you for the output directory, type "out", assuming you named that way your output folder
                Code:
                C:\bios\BIOSUtilities-main>python main.py E7440A28.exe
                Enter output directory path: out
                E7440A28.exe
                Dell PFS Update Extractor v25.07.01
                Extracting Dell PFS 1 > E7440A28 > Firmware
                It will extract inside the C:\bios\BIOSUtilities-main\out\E7440A28.exe_extracted\Firmware folder
                Code:
                C:\bios\BIOSUtilities-main\out\E7440A28.exe_extracted\Firmware>dir /b
                1 E7440A28 -- 1 System BIOS vA.28.bin
                1 E7440A28 -- 10 Model Information v1.0.0.0.txt
                1 E7440A28 -- 2 Embedded Controller vA.14.bin
                1 E7440A28 -- 3 Gigabit Ethernet v0.6.bin
                1 E7440A28 -- 4 Legacy Video OROM v1039.1F.17.bin
                1 E7440A28 -- 5 Legacy RAID OROM v12.7.0.1936.bin
                1 E7440A28 -- 6 Intel Management Engine (VPro) Update v9.5.65.3000.bin
                1 E7440A28 -- 7 Intel Management Engine (Non-VPro) Update v9.5.60.1952.bin
                1 E7440A28 -- 8 ACPI OS support v0.0.0.1.bin
                1 E7440A28 -- 9 Intel AntiTheft v3.0.0.18.bin​
                It's not ready for flashing, you may have to use UEFITool 0.28 to replace the BIOS region on your BIOS dump (keep a copy of the original dump), for the ME region i don't know, you may ask the experts here, there's 2 ME versions, one vPro, one non-vPro, i don't know which one is right
                • volinakis
                  • Jan 2021
                  • 2875
                  • N/A
                  try Dell_pfs_extract ...
Name:	Screen Shot 2025-07-22 at 05.02.24.png
                  • jaglion19
                    • Oct 2017
                    • 111
                    • TURKEY
                    1.
                    Code:
                    Code:
                    7-zip.dll
                    7-zip32.dll
                    7z.dll
                    7z.exe
                    7z.sfx
                    7zCon.sfx
                    7zFM.exe
                    7zG.exe
                    big_script_tool.py
                    TianoCompress.exe
                    UEFIExtract.exe
                    UEFIFind.exe
                    Code:
                    Code:
                    Code:
                    E7440A28.exe
                    Code:
                    Thank you very much king, I did what you said one by one and as a result I was successful and I am happy. Thank you for your hard work.
                    • jaglion19
                      • Oct 2017
                      • 111
                      • TURKEY
                      The device I use is an imac, actually I will try this on the Mac side at the first opportunity. I struggled because the Dell FPS extractor was not working on the Windows side. It didn't work when I did it in Windows like you did. Thank you friend, I solved it, but I will try it on the Mac side at the first opportunity. Thank you very much for your interest. Good luck with your work.
                      • jaglion19
                        • Oct 2017
                        • 111
                        • TURKEY
                        I would be very happy if you could help me with one more issue, the bios is in good condition, thanks to you, I made it factory clean. But I don't know how to do EC on older models. I would be very happy if you could help me on how to do the EC of this device.
                        • volinakis
                          • Jan 2021
                          • 2875
                          • N/A
                          read/write EC with a programmer capable of reading MEC. Connect it to JDEG1. Read this thread for howto:
                          https://www.badcaps.net/forum/troubl...ith-info-block
                          • jaglion19
                            • Oct 2017
                            • 111
                            • TURKEY
                            thank you master, thank you
                            • AWENA
                              • Sep 2020
                              • 39
                              • Polska
                              In the folder unpacked via Dell_PFS_Extract, there are two versions: the first with date codes "0CB9,0CBA,0CBB" and the second with date code "0CBC". When choosing, I relied on the ME region version: the "0CB9,0CBA,0CBB" has version 18.x (that's why I chose it), and "0CBC" has 16.x. But if the CSME versions were the same, how can I figure out which one I need? I've often seen three or even four versions in one folder. How can I figure out which version we need?
                              https://ibb.co/MxLHzgMn
                              P.S.: I also noticed that different versions of Dell_PFS_Extract (e.g., 6.0 and 4.5.1) unpack files differently. Here's a comparison of the same BIOS region unpacked using different versions of Dell_PFS (I'm attaching a screenshot).
                              https://ibb.co/HL7bNFzF
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • zandatsu07
                                Dell PFS Update Extractor extracted multiple files
                                by zandatsu07
                                I'm using dell pfs update extractor but it extracted multiple files instead of 1 bin file, what am i doing wrong here?
                                My PC
                                Dell Optiplex 7050 Micro...
                                04-10-2024, 07:58 PM
                              • Akhlz001
                                by Akhlz001
                                09-20-2025, 07:15 PM
                              • master3112
                                by master3112
                                07-29-2025, 01:55 PM
                              • DanPoka
                                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                by DanPoka
                                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                02-15-2025, 05:05 AM
