Need Bios for Dell Ispiron P75F001
  • mefausto
    • Jun 2023
    • 17
    • italy
    I need Bios for Dell Ispiron P75F001.
    I tried to download a dump of the Dell Inspiron 15 P75F model that I found here but I think it's not the right one. Why doesn't he leave. With my original one the PC starts up, you see the Dell logo and then it turns off immediately afterwards.
    Thank you​
  • peste
    • 13880
    • ROMANIA
    Thank you
    post the contents of the bios chip even if it is corrupted..post S/T, full name and model, motherboard model,etc.
    • mefausto
      • Jun 2023
      • 17
      • italy
      On the card it is written: CAL50/DAL10 LA-F115P Rev:1.0 (A00) 2017-08-26
        SMDFlea commented
        Editing a comment
        The 7 digit service tag should be on a sticker on the base cover
    • mefausto
      • Jun 2023
      • 17
      • italy
      SERVICE TAG: 4J31Z32
      • osman68i
        • May 2015
        • 354
        • The Netherlands
        tested by myself working bios
        try
        • hoaca388
          Badcaps
          • Jan 2022
          • 12429
          Service tag 4J31Z32 belong to Inspiron 5570.
          • mefausto
            • Jun 2023
            • 17
            • italy
            try
            Thanks so much!!
            It worked!​
            • mefausto
              • Jun 2023
              • 17
              • italy
              Flashing the bios worked, however I find that every time Windows update downloads the bios update, the computer reboots and never starts again. I don't know how to do it! I should disable all updates, but I don't want to.
              • osman68i
                • May 2015
                • 354
                • The Netherlands
                try update manually
                  • 22216
                  Look in the bios settings for UEFI Capsule Firmware Updates ,if it`s there set it to disabled.
                  • mefausto
                    • Jun 2023
                    • 17
                    • italy
                    try update manually
                    Tried it, same thing.​
                    • mefausto
                      • Jun 2023
                      • 17
                      • italy
                      Thank you
                      I did this, also disabled driver updates on Windows via group policy.​
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
                      • capoplays
                        Help with BIOS update on Dell G15 5515 after chip replacement
                        by capoplays
                        Hey everyone,
                        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                        When I check the BIOS using the F12 menu Flash...
                        10-24-2025, 06:53 AM
                      • Akhlz001
                        by Akhlz001
                        09-20-2025, 07:15 PM
                      • Sathsul
                        Dell Latitude 5431 issues with dumping bios
                        by Sathsul
                        So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                        The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                        However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                        10-28-2025, 07:49 AM
