Need Ec bios Lenovo ideapad 1 14igl05 please
  • diegovag
    • Feb 2018
    • 5
    • argentina
    Hello, can someone help me with the file EC bios dump for the Lenovo ideapad 1 14igl05? Power blink problem, thanks!
  • vladimir1909
    • Apr 2016
    • 20
    • Peru
    tengo este de ideapad 3
    puedes probarlo
    I have this one from ideapad 3
    you can try it​
    in English please..
    • diegovag
      • Feb 2018
      • 5
      • argentina
      Hello, your file is for a different model, the motherboard use nuvoton EC. Thanks
        • 20855
        Post your bios backup ,laptop serial number and the motherboard model number https://www.badcaps.net/forum/troubl...before-posting
        • pcwhiz24
          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
          by pcwhiz24
          Model: Lenovo IdeaPad 3 14ADA05 81W0
          S/N: PF2BZS7D
          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
          I already have a CH341A programmer...
          04-07-2025, 07:10 PM
        • mximiliandz
          help bios lenovo ideapad s145-14iil type 81w6
          by mximiliandz
          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
          06-20-2025, 06:50 AM
        • carabas20
          BIOS bin file for Lenovo Ideapad 3 17ADA6
          by carabas20
          Hello i need BIOS bin file for Lenovo Ideapad 3 17ADA6 S/N PF3AALFM.
          I have updated my bios from the official website , and after the laptop restarts it went to black screen and now i can not do anything. I have been trying to flash the bios with CH341A but from the office website i can see only the CAP file. I have need trying to modify the cap file following the guides and video from the forum but no luck.
          If anyone has a dump of original bios for this model will be great or clean the faulty bios for me , i have attached my backup bios...
          06-01-2023, 01:19 PM
        • Forest79
          by Forest79
          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
          07-23-2023, 07:39 AM
        • survivalbloke
          Unable to extract bios file from Lenovo bios exectuable
          by survivalbloke
          I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
          Code:
          "innoextract 7wcn38ww.exe"
          it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
          The trouble I'm having is that I'm not getting the newly...
          06-12-2024, 07:55 AM
