HP Omen 17-ck****** bios
  • allyto
    • Dec 2023
    • 6
    • TANZANIA
    Help help please i have Hp Omen 17 ck1022tx does not display ..i need new bios bin..i have attached the Backup bin
  • hoaca388
    Badcaps
    • Jan 2022
    • 12645
    Seria number ?
    • allyto
      • Dec 2023
      • 6
      • TANZANIA
      Originally posted by hoaca388
      Seria number ?
      SN# 5CD2335W.
      DAG3LBMBCD0 : REV
      • hoaca388
        Badcaps
        • Jan 2022
        • 12645
        SN# 5CD2335W.
        DAG3LBMBCD0 : REV
        Click image for larger version  Name:	2024-11-13 16_28_29-Official HP® Laptop Drivers and Software Download _ HP® Support.png Views:	4 Size:	81.3 KB ID:	3506289
          • 22772
          Posts moved to a new thread.
          Badcaps relies on your donations to pay for hosting ( Currently AWS is $8000 alone) site advertising goes nowhere near to covering these costs. To keep everything that you and i rely on for free,Please consider donating, thank you.
          • allyto
            • Dec 2023
            • 6
            • TANZANIA
            Plesa Help ..I have re-read the chip of HP Omen 17-ck1022TX
            Prod ID 6JOW2PA#ACJ
            I have also attached the old backup ...pls pls help
            • shiyab
              • Sep 2023
              • 1892
              • india
              Prod ID 6JOW2PA#ACJ
              hi try not dmi add
              • Kiki Cares
                • Feb 2022
                • 29
                • Nigeria
                HI GUY"S I NEED THE CLEANME FILE FOR OMEN by HP Laptop 17-ck2001nr (837W7UA)
                SN:::5CD319DT53
                ​NOT DISPLAYIN
                PLS HELP
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12645
                  SN:::5CD319DT53
                  ​NOT DISPLAYIN
                  PLS HELP
                  • mtherana
                    • 122
                    • South Africa
                    Need Help with clear ME laptop only blinks once then off no fan spin.
                    HP Omen 17-ck1000ni
                    S/N: 5CD231GLR1
                    • peste
                      • 14406
                      • ROMANIA
                      HP Omen 17-ck1000ni
                      S/N: 5CD231GLR1
                      try post #7..
                      DMI 801000 - 8020FF
                      KEYWIN BA6000 - BA603F​
                      • mtherana
                        • 122
                        • South Africa
                        Originally posted by peste
                        try post #7..
                        DMI 801000 - 8020FF
                        I tried it laptop reboots continuously with no display as if its doing Bios recovery but never displays just on and off can even got 20-min and still nothing happens.
                        • peste
                          • 14406
                          • ROMANIA
                          Maybe the laptop has another problem.
                          • trepachka
                            • Oct 2022
                            • 481
                            I have this HP Omen 17-CK2000 IDS Base computer. It is not posting. Upon start, the keyboard lights up, the CPU fan starts running and both the CPU and the GPU get warm quickly.
                            I removed the memory to test the computer and the Caps Lock flashes 3 long and 2 short bursts indicating RAM failure. This suggests that perhaps the BIOS is corrupted.
                            Please, help me fix the BIOS file on this computer.
                            S/N: 5CD3295CHF
                            The original BIN file is attached. Thank you.
                              SMDFlea commented
                              Editing a comment
                              3 long and 2 short bursts indicating RAM failure can be loose ram slot pins or cracked solder balls under the cpu.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12645
                            S/N: 5CD3295CHF
                            OMEN 17.3 inch Gaming Laptop PC 17-ck2000 IDS Base Model
                            • Dowhile
                              • Sep 2020
                              • 35
                              • Italia
                              Hi the laptop does not post... caps lock no activity, no backlight, fans and led working.. can u please check the bios? thanks
                              MB DAG3LAMBCE0 REV. E
                              THANKS
                                • 22772
                                THANKS
                                Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                                Type the laptop serial number, full name and model, motherboard model, etc.
                                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                                • trepachka
                                  • Oct 2022
                                  • 481
                                  I applied the new BIOS, no changes. The CPU fans begins to spin, eventually the GPU fan also starts spinning due to heat accumulating on the heatsink.
                                  If I intentionally remove the RAM, the Caps Lock flashes indicating RAM failure. So, this tells me computer is alive but still no post
                                  • Dowhile
                                    • Sep 2020
                                    • 35
                                    • Italia
                                    HI GUY"S I NEED THE CLEANME FILE FOR OMEN by HP Laptop 17-ck1008nl
                                    SN:::5CD240BGJW
                                    NO POST . FAN SPINS . NO DISPLAY NO BACKLIGHT
                                    PLS HELP​
                                    • peste
                                      • 14406
                                      • ROMANIA
                                      SN:::5CD240BGJW
                                      PLS HELP
                                      bios extracted from HP website update for OMEN by HP Laptop 17-ck1008nl (673L5EA)
                                      DMI 801000 - 8020FF
                                      KEYWIN 8A6000 - 8A603F​
                                      • JoWed
                                        Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                        by JoWed
                                        Hello Community,
                                        I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                        07-01-2025, 09:32 AM
                                      • Dani Rahal
                                        hp omen 17-cb0247ng bios
                                        by Dani Rahal
                                        Hi can some one help me plz
                                        i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
                                        i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
                                        the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
                                        i have the orginal bios if some one can see what the problem or...
                                        05-30-2025, 09:11 AM
                                      • Blur3195
                                        HP Omen 16-u0000sl. bios
                                        by Blur3195
                                        Hi, I have a problem with my HP Omen 16-u0000sl.
                                        I have a corrupted dump from which I extracted the DMI and inserted it into a stock BIOS. With the corrupted dump, the Caps Lock light blinks twice normally and twice quickly (BIOS corrupted). With the stock BIOS plus the DMI, the laptop starts a series of reboots but never initializes. I would be very grateful if someone could help me; I think maybe the DMI area is corrupted....
                                        08-22-2025, 11:24 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • zerbatin
                                        HP Omen 16-c0825no BIOS.
                                        by zerbatin
                                        I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
                                        I have tried using this DUMP but with no go,
                                        https://www.badcaps.net/forum/troubl...os#post3210916
                                        My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
                                        07-17-2025, 02:14 PM
