HP factory bios patcher
  • krkr_20033d
    magic
    • Apr 2019
    • kfs
    #41
      • 24330
      Added the long overdue script to post 1 to put into MPM - HP_Factory_Mode_7_MPS
      • m0ck
        • Apr 2026
        • Israel
        #43
        Hello. I have EliteMini 600 G9 with incorrect DMI data (replaced motherboard).
        is it possible to make the bios backup without using software, patch it and flash it back with software? OR do i need to make full BIOS dump with a programmer to be able to edit it and flash back with a programmer?
        • shiyab
          • Sep 2023
          • 3420
          • india
          #44
          post olde bios dmi and new bios dmi
          • harounHD
            • Feb 2017
            • 54
            • Algรฉrie
            #45
            with added 6 and 7 scripts does it run with full script or do i have to run it individualy
            • harounHD
              • Feb 2017
              • 54
              • Algรฉrie
              #46
              i did all that still password on
                SMDFlea commented
                Editing a comment
                The scripts only work with old bios versions , won`t work with newer G9 bios versions , won`t work with G10 or G11 models.
            • SERVILAP
              • Aug 2014
              • 24
              • mexico
              #47
              HP ZVOOK FURY 15 G7
              Hi, could you help me? When I run any script, I get this error. I tried them one by one and it does the same thing.
              • shiyab
                shiyab commented
                Editing a comment
                this no 16 mb chek
                red again
            • Sparo
              Quicksilver
              • Jan 2022
              • 3731
              • M\A
              • Anime, Edge Computing, Football, Snooker
              #48
              Originally posted by SERVILAP
              HP ZVOOK FURY 15 G7
              Hi You have to post the Serial Number with every single request (As per the Forum rules)
              > RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING* - Badcaps
              Also, explain the issue with the machine is. Why are you running all these scripts? BIOS Password?
              Enjoying our forum? Subscribe to unlock extra perks!
              >> Upgrade here <<
              ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
              • SERVILAP
                SERVILAP commented
                Editing a comment
                Yes BIOS password
              • Sparo
                Sparo commented
                Editing a comment
                You need to run the script on the full SPI image using an external SPI programmer
                Running it only on the BIOS region that was dumped with software will not work
            • shiyab
              • Sep 2023
              • 3420
              • india
              #49
              HP ZVOOK FURY 15 G7
              post snid and issu?
              • SERVILAP
                SERVILAP commented
                Editing a comment
                CND1105J2H
                Produc ID 368Y4EC#ABA
            • nowell96
              • Feb 2026
              • 24
              Thanks so much for this. I am having difficulty with the instructions afterwards though, and I want to make sure I'm doing it correctly. So, after dumping my bios, running the script on it, and loading it back onto my chip, I was able to get into the bios. Upon startup, it says "System is booting in manufacterer mode". I'm in the BIOS now, but the DMI instructions I'm not understanding. I apologize for the trouble, but what comes next exactly? Thanks again!
              • Sparo
                Quicksilver
                • Jan 2022
                • 3731
                • M\A
                #51
                Hi flash back your original MAIN BIOS file (The one before patching)
                If it still doesn't work then post it along with the Serial Number of the machine
                >> Upgrade here <<
                ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                • nowell96
                  • Feb 2026
                  • 24
                  I had to have missed something. So I dump the bios with a password on it, patch the bin, then erase the chip, write the patched bios on it, boot into bios, reset to defaults and save, then I erase the chip again and write the original bios, the unpatched one with a password, back on the laptop? Sorry, I just feel like I have half the instructions lol. Am I missing some info that's described here - ?
                  "Hello! After use the patcher, I need to do like had been told in other hp bios unlock posts: "At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in to bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover, or use hp bcu tool"? I didn't tried it yet, but i'm planing to do."
                  Thanks again for your help
                  • Sparo
                    Quicksilver
                    • Jan 2022
                    • 3731
                    • M\A
                    #53
                    Yes, write back the original BIOS file "with a password" (this may work depending on the model)
                    If it doesn't work, post that original file and I'll extract DMI for you to fill using BCU (stickers don't contain all)
                    >> Upgrade here <<
                    ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                    • nowell96
                      • Feb 2026
                      • 24
                      k. ya unfortunately when I loaded the original bios back on the chip it still had the password on it. So after you attain the info from my bin file, you extract the DMI from it, and then once I have that, I can use the HP BIOS Configuration Utility (BCU) to fill it in, and the password will be gone? Just want to make sure I understand. I'm gonna try to write down the full instructions somewhere so if it happens again I have them lol. Here's the BIOS, thanks
                      • Sparo
                        Quicksilver
                        • Jan 2022
                        • 3731
                        • M\A
                        #55
                        So, for this model, you can either rewrite the BIOS without the password (patched using the script) and then fill in these DMI using BCU
                        Or leave the BIOS chip as it is and instead unlock the EC chip on the backside of the motherboard
                        P.S: Normally you should've posted the SN as instructed, but I'm posting all DMI anyway
                        Serial Number: 5CG1080YRN
                        Product #/SKU: 227Q0UC#ABA
                        CT Number: PJSCK00WBEU09B
                        Description: HP ZBook Firefly 14 G7 Mobile Workstation
                        BuildID: 20WWCMBT601#SABA#DABA
                        Feature Byte: 3X476J6S6b7B7M7R7U7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhkjhk3k8kDmE.DR
                        MAC Address : 14:CB:19:09:52:3C
                        Universally Unique Identifier (UUID): 53BE282D4B50FA41AD53ADF3BEFD5590
                        UUID (standard format): 2D28BE53-504B-41FA-AD53-ADF3BEFD5590
                        MS Digital Marker: 010000000000000001000000000000001D0000004E595447362D44344233432D593947384B2D34364433562D334A334750
                        >> Upgrade here <<
                        ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                        • nowell96
                          • Feb 2026
                          • 24
                          Ya I'd rather not have to disassemble it. So I write the patched bin file back onto the laptop, then fill in the DMI info you gave me using the BCU program? This is the unlocked one I got using the patcher -
                          • Sparo
                            Quicksilver
                            • Jan 2022
                            • 3731
                            • M\A
                            #57
                            Yes, use the one that unlocked the laptop with the message on startup: "System is booting in manufacturer mode"
                            That way, you can use BCU to fill in the DMI information, and then lock Manufacturer Mode afterward
                            >> Upgrade here <<
                            ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                            • nowell96
                              • Feb 2026
                              • 24
                              I'm gonna lose my damn mind dude lol. Now, after putting the unlocked bin back on there (twice to double-check), I don't get the manufacturer mode anymore. It goes straight into AMT Disabling, then if I try to go into BIOS I get hit with the password again. If I take it apart and get the 16mb bin, will the 32mb chip still have the password on it? How will I handle this chip? Also, I'm not sure I'm running your script right. It runs, and then stops, but I don't know if it found what it was looking for, or if the necessary replacements have been made or anything.
                              When I run the full script, following the first instructions in the post, it loads through 4 times (I'm assuming it's going through the scripts one by one), then stops at this screen. At that point, I clicked save as, and saved a copy. Then used hxd to ensure that the original locked and the new one I just saved, are different. Then I erase the chip, verify, load the unlocked script, write and verify again. What's my best course of action here? Sorry for the questions. I'm not at all opposed to someone just doing it for me by uploading the bin file, but I want to be able to do this stuff myself. I buy used laptops frequently, and I don't want to have to bug you guys each time I need something unlocked lol
                              EDIT: I'm also trying another tool "HPUnlocker.py". I'll see how that goes. RCUnlocker didn't work because it's a 32mb chip
                              • Sparo
                                Quicksilver
                                • Jan 2022
                                • 3731
                                • M\A
                                #59
                                You can actually use RCUnlocker even on 32MB chips
                                Read this > https://www.badcaps.net/forum/troubl...27#post3849527
                                >> Upgrade here <<
                                ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
                                • nowell96
                                  • Feb 2026
                                  • 24
                                  Good grief you guys kick a lot of a**. Thanks so much, I'll try this. I've been cataloguing everything and have a folder with all the tools I've been through, so your time definitely wasn't wasted lol. I'll report back
                                  • MTT97
                                    I managed to brick the XPS 15 9550 Bios just by changing some settings and hit save...
                                    by MTT97
                                    Long story, i bought this XPS 15 9550 that came without a ram and ssd. I had a known working Crucial 8GB 3200Mhz DDR4 ram laying around so i tried it and the laptop would boot to bios but once exiting bios (without making any changes) it will get stuck on a black screen and only fans and keyboard would turn on. To get it ''working'' again i hard reset it by unplugging the battery and ac adapter and leave it for 5-10 min. I attempted to install windows but it froze before i even got to the language and region selection page. I then ordered some 2400Mhz rams which worked and i was finally able to...
                                    01-31-2026, 06:18 PM
                                  • macabook
                                    ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
                                    by macabook
                                    Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
                                    ๐Ÿงฉ Initial Issue
                                    07-24-2025, 02:17 PM
                                  • cr4zychriss
                                    by cr4zychriss
                                    • Rebrand: PC Specialist
                                    11-14-2025, 04:04 PM
                                  • Arzigol
                                    Acer Nitro Lite 16 NL16-71G (V1.19) - BIOS Unlock / Advanced Menu / CFG Lock
                                    by Arzigol
                                    Hello everyone!
                                    I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
                                    Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
                                    Laptop Information
                                    Model:
                                    Motherboard:
                                    CTE_NB_NL160P1G_RTH (NB6807C)
                                    CPU:
                                    Intel...
                                    Today, 02:27 AM
                                  • pirati
                                    by pirati
                                    When the laptop arrived (without a charger and SSD), I connected a charger and confirmed with a multimeter that it was charging the battery. However, when I tried to power it on, only the backlight of the secondary display came on. There was no image, and it didnโ€™t boot into the BIOS.
                                    I decided to try flashing a new BIOS, but since I didnโ€™t want to desolder...
                                    10-27-2025, 04:20 PM
