how to read/write XMC25RU256CIX0 with RT809F
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    have new A15 tuf that have this bios ic XMC25RU256CIX0 but my RT809F cannot find it in database. i have newest version of software 20240116. found nothing to be help on ifix forum
    how to manually add it?
  • volinakis
    • Jan 2021
    • 2872
    • N/A
    Settings - Add chipset partnumber. Fill fields with required data and in algoritm equal set it to W25Q256FW (is 1.8V chipset). or simply chose W25Q256FW and use 1.8V adapter.
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • araxnido
      Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
      by araxnido
      Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
      When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
      06-10-2025, 09:26 PM
    • ChaosLegionnaire
      bug of the month: write caching setting for the hard drive in device manager
      by ChaosLegionnaire
      i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
      so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
      10-06-2019, 01:39 PM
    • feherhollo
      WSON8 NEW Bios Chips READ, ERROR, ETC.
      by feherhollo
      I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
      I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
      For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
      11-26-2023, 09:33 AM
    • CapThatBrass
      RT809F Chip Write Failure - Winbond 25R256JV
      by CapThatBrass
      I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
      I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
      The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
      10-04-2022, 11:56 AM
