Mecer Z140C-Edu+ BIOS request
  • KagisoGalane10
    • Apr 2022
    • South Africa
    Hello Tech's, i have mecer Z140c - Edu+ laptop with corrupted BIOS, i have attached the corrupted original file.
    anyone with file please help
    Model Z140C- Edu+
    Board Number: EM_IA530_200B_ENE_YI_8_V1.0
    • 21497
    Post the laptop serial number. It might be IFP*************** ?
    • KagisoGalane10
      • Apr 2022
      • South Africa
      serial number tag is not visible
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • FalconPunch
        Surface Pro X 1876 Bios corrupted
        by FalconPunch
        Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
        Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
        08-09-2025, 03:56 AM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • hotcrossedbuns999
        M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
        by hotcrossedbuns999
        My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
        1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
        2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
        3. I could only locate two chips that look like bios chips. Could someone verify this
        01-03-2025, 12:32 PM
