I need bin file for Acer CC315-72G
  • Jeff-M
    • Aug 2024
    • 24
    Hello guys, I need bin file for Acer CC315-72G.
    The computer powers on, keyboard becklight stays on, no post. I assume that's BIOS issue.
    thank you
    Bios read from laptop:
    complete model : CC315-72G-70j4
    SNID: 04100808376​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12113
    thank you
    SNID: 04100808376
    ConceptD CC315-72G
    • Jeff-M
      • Aug 2024
      • 24
      thank you for the bin file. I tried that but still the same.. Power goes in, back light stays on, fans don't spin. Any idea what else could be the issue?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        check ram clean it with eraser and swap to other slot or test a same ram
        • Jeff-M
          • Aug 2024
          • 24
          I have done that already. tested with different RAMs, still the same.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            youl need to start checking voltages
            • wasyl
              Acer Nitro AN515-46 HH51R LA-M002P R1A BoardView File + schematic
              by wasyl
              Hi, did not found here so uploading to help...
              09-15-2025, 07:40 AM
            • Mirenia
              Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
              by Mirenia
              got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
              The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
              If this happened once, then the laptop only runs for a few minutes until restart.
              This happens regardless while staying in windows or uefi or in a linux environment.
              At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
              01-05-2025, 05:15 PM
            • ahmarzo
              Acer laptop battery draining issue
              by ahmarzo
              Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
              Help me to diagnose this issue as there is no shortage in the inputs MOSFET
              08-02-2025, 06:39 AM
            • EbrahimSiami
              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
              by EbrahimSiami
              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
              **What I have tried so far:**
              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
              07-02-2025, 02:31 PM
              09-06-2024, 05:27 AM
