BIOS Dell G15 5530 LA-M531P
  • kain0007
    • Jan 2017
    • 14
    • México
    #41
    Originally posted by LBTT1121
    try and feedback
    LBTT1121, hello master.
    I appreciate your support and your time. Unfortunately, it didn't work; it's still drawing 0.4066 A from the power supply. It does the same thing with the original bin file.
    • LBTT1121
      • Nov 2024
      • 1023
      • Việt Nam
      #42
      try and feedback
      • kain0007
        • Jan 2017
        • 14
        • México
        #43
        try and feedback
        Thank you so much. I appreciate your help. It worked.
        • LBTT1121
          • Nov 2024
          • 1023
          • Việt Nam
          #44
          welcome , Bro
          • mizzed
            Bios Request - Dell Precision 5530 2in1 LA-F211P rev 1.0 - updated
            by mizzed
            Hi, Would anyone have a bios dump for a Dell Precision 5530 2in1 LA-F211P rev 1.0.
            Following a failed bios, I had a new bios chip programmed with the the XPS 15 9575 2in1 LA-F211P rev 1.0, which the motherboard has identical model numbers, (having not being able to find a 5530 2in1 bios) however both in bios and os, the Vega graphics, and sound boards are not detected or installable, everything else worked fine. The only difference I can see is that although the motherboards are nearly identical is that they have slightly different CPU/GPU 8705g vs 8706g.
            If anyone...
            01-05-2023, 06:53 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • Sathsul
            Dell Latitude 5431 issues with dumping bios
            by Sathsul
            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
            10-28-2025, 07:49 AM
