Finding AMI BIOS bin-file for the Toposh i7-1065G7 laptop.
Toposh i7-1065G7 BIOS
Post the full laptop model number and serial please https://www.badcaps.net/forum/troubl...before-posting -
I checked it again:
Serial number is on the memory slot of the computer check attached image.
maybe either
NFR21100010251
or
PBGLX255M1B1LAA024483
It looks below is the laptop serial number:
And I hope to find AMI BIOS bin-file for this laptop for flashing it again.
1 PhotoComment
It would be a good practice for an AliExpress seller to record the serial numbers of laptops and their components along with the customer's address and information. Here are a few reasons why: 1. https://www.bing.com/search?form=SKPBOT&q=Traceability: Keeping a record of serial numbers helps in tracking the product in case of any issues, such as defects or recalls https://www.serial.io/blog/managing-serial-numbers. 2. https://www.bing.com/search?form=SKP...and%20Support: It makes it easier to provide warranty services and support, as the seller can quickly verify the purchase details https://www.serial.io/blog/managing-serial-numbers. 3. https://www.bing.com/search?form=SKP...%20Prevention: Recording serial numbers can help prevent fraud and ensure that the correct product is returned or serviced https://www.serial.io/blog/managing-serial-numbers. 4. https://www.bing.com/search?form=SKP...tomer%20Trust: It enhances customer trust, knowing that the seller is organized and prepared to handle any potential issues https://www.serial.io/blog/managing-serial-numbers. Implementing this practice can improve overall customer satisfaction and streamline after-sales support.
It looks they don't feel obligated to follow the best practices for online sellers.
The BIOS version is:
American Megatrends Inc. ICELAKE_330.03, 7/3/2021
However the problem seemed to be defective keyboard instead. Power button shouldn't be in the keyboard itself and was installed separately now and external keyboard must be used instead.
1 PhotoComment
by thxd43Hello, first of all, excuse me, I am using the translator, English is not my native language.
I have a Lenovo ideapad 330S - 14IKB laptop.
The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a... -
by legendkrayHi,
I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...-
Channel: BIOS Requests ONLY!
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
by Loli PopuHello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
by bschwandHi all,
as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...-
- Loading...
