Please clean BIOS - HP Envy 15-ds1063cl
  • survivalbloke
    • Aug 2021
    • 309
    This device will only post if I remove the battery and clear CMOS. Then I get the warning that CMOS was reset. When I choose to continue, it will not boot, just black screen. CPU is warm, power light is on. Pressing power button immediately powers off. Feels like maybe a BIOS issue? Here's the dump file. Can someone review? SN:8CG024309F
    • 22035
    Post the serial number please https://www.badcaps.net/forum/troubl...before-posting
    • survivalbloke
      • Aug 2021
      • 309
      Originally posted by SMDFlea
      Sorry
      8CG024309F
      • hoaca388
        Badcaps
        • Jan 2022
        • 12362
        Sorry
        8CG024309F
        HP ENVY x360 Laptop - 15-ds1063cl
        • survivalbloke
          • Aug 2021
          • 309
          Thanks!!!
          • survivalbloke
            • Aug 2021
            • 309
            That worked perfectly! Hey, how can I learn to do whatever it is that you did to my BIOS file to fix it? I'd love to add this to my skillset and not have to rely on others as much.
            • survivalbloke
              • Aug 2021
              • 309
              AWW MAN!! So, everything was totally fine, but I would have a warning on boot that the manufacture programming mode is in unlock mode - OEM keyboard not set. So I followed the instructions https://www.youtube.com/watch?v=T64vMCLDQ_s in that video, and it broke. Now the machine is doing the same thing it was doing when I came here for a BIOS fix. What did I do wrong?
                • 22035
                Extracting BIOS/EC firmware from update packages
                https://www.badcaps.net/forum/troubl...26#post1622426
                7.2.4. HP
                [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948 and
                [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                ​Those guides will help you ID the right bios version and extract it from the update. What the guide doesn`t cover is copying the DMI from the old bios to the new one.Its reltively easy to do with a hex editor.
                  • 22035
                  Try this one.
                  • survivalbloke
                    • Aug 2021
                    • 309
                    Try this one.
                    The machine boots fine with this image(thanks!), but I'm still getting the pre-boot warning about unlocked mode, and no OEM keyboard selected. I'm afraid to follow the bios configuration steps I linked above. WHat should I do?
                      • 22035
                      You can close MPM with BCU but first,in the config.txt file is there a section for Keyboard Type . Is the keyboard US qwerty, is the OS language set to US english
                      • survivalbloke
                        • Aug 2021
                        • 309
                        Language is set to English. For keyboard, there is no option for US qwerty. See image attached.
                          • 22035
                          Change it to BIOS default ,lock MPM and see what happens.
                          • survivalbloke
                            • Aug 2021
                            • 309
                            That broke it again Upon issuing the /setconfig command, I got a success message in green, indicating that a reboot or shutdown was necessary. Upon restart, The fans engage for about 2 seconds, cpu gets warm, caps lock key is functioning correctly, but screen is black. The power button light is on as well as the charging light. If I press the power button, the power light immediately turns off and the cpu begins to cool. This machine seems to run perfectly fine until I /setconfig.
                            • Beepulet
                              • Nov 2023
                              • United Kingdom
                              Can someone please help with a CLEAN bios for HP Envy 15-eu0005sa
                              SN:8CG1361KTJ
                              aTTACHE ORIGINAL BIOS
                              • danito
                                • Jun 2016
                                • 1108
                                • Romania
                                SN:8CG1361KTJ
                                you have everything you need here:
                                https://www.badcaps.net/forum/troubl...dx#post3696650
                                your BID: 0888A
                                • Kenzi
                                  Cannot modify HP Envy 15 ep-00008na BIOS
                                  by Kenzi
                                  I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                                  I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                                  11-09-2023, 05:22 AM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • Loki_Fido
                                  BIOS request for HP ENVY x360 2 in 1 Laptop 13-bf0***** PLEASE
                                  by Loki_Fido
                                  Hi ya folks,
                                  Hope everyone's having a good day.
                                  I have a HP ENVY x360 2 in 1 Laptop 13-bf0002TU with nothing on the screen.
                                  The laptop starts but no display. Connecting to an external monitor give me nothing too. Ive attached my original backup bios
                                  Make HP ENVY x360 2 in 1
                                  Model 13-bf0002TU
                                  S/N CND3171C5T
                                  Prod ID 6L2F0PA#ABJ
                                  I looked up at this site before writing this request. And there was a link. But i couldn't download any files from it.
                                  Any moderator could look it up, if possible? It says, "Invalid file specified"...
                                  06-16-2025, 08:02 PM
