Unable to extract bios file from Lenovo bios exectuable
  • survivalbloke
    • Aug 2021
    • 313
    I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
    Code:
    "innoextract 7wcn38ww.exe"
    it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
    The trouble I'm having is that I'm not getting the newly created executable. It does seem to extract a "BIOS.cap" file, but I don't believe that's what I'm looking for, and that's also not in accordance with the instructions. Can anyone help walk me through this?
    • 22169
    The bios.cap is the bios update. It needs editing with a hex editor to remove the capsule header,then editing to the right size.
    https://www.badcaps.net/forum/troubl...k-bios?t=80861
    https://www.badcaps.net/forum/troubl...ial?t=98038​
    • survivalbloke
      • Aug 2021
      • 313
      As always, you are AMAZING! Thanks!
      • survivalbloke
        • Aug 2021
        • 313
        SMDFlea
        Quick follow up question: In your instructions for removing the header, you state the offset should be block 317. In your provided screenshots, that shows capturing everything up to the first "FF". However, in my CAP file, it looks like there are 4 more blocks with data before the first "FF". Should I stick with 317, or increase it to capture the next 4 blocks?
          • 22169
          Originally posted by survivalbloke
          SMDFlea
          Those guides are examples.It doesn`t mean your bios is the same or the block should be 317.Some updates can be named *.CAP and not have any capsule header at all. Post a link to the update and we can take a proper look at it
          • survivalbloke
            • Aug 2021
            • 313
            Sure thing! https://drive.google.com/file/d/1-7c...ew?usp=sharing
              • 22169
              It is 0 - 317 .After you`ve deleted that set the first offset to 0 and enter 800000 as the length ,copy that to a new file and you`ve got a newly extracted 8MB bios. If you stil have the old bios then you can copy the DMI from it to the new one
              • survivalbloke
                • Aug 2021
                • 313
                Ughh... The dread "File size larger than IC size". This is a Lenovo IdeaPad 330S-15ARR​, board part# 431204725060. Pretty small board, and the only chip on it appearing as a bios chip is W25Q64FW. I'm trying to correct a problem where the device will power up, I get fans and all, but no display, no caps lock or anything like that. Really feels like a corrupt BIOS. I got the idea from this post: https://www.badcaps.net/forum/troubl...pad-330s-15arr
                  • 22169
                  Read the part number off the top of the chip and post it. There`s a number of different reasons for that dreaded message.If you`re using the original ch341a software use NeoProgrammer instead.Sometimes with the original software the Auto-detect will choose the wrong chip. Whichever software you use choose the chip manually from the supported list. If the chip marking is W25Q64FW the voltage is 1.8V so use a 1.8V adapter.
                  • survivalbloke
                    • Aug 2021
                    • 313
                    The number off the chip is 25Q64FWSIQ. I was using ASprogrammer. I'll go look for and download neoprogrammer. I'll go ahead and try the 1.8v adapter. Dor some reason I had it in my head that the CH341a would automatically step the voltage down but now I remember otherwise.
                    • survivalbloke
                      • Aug 2021
                      • 313
                      SMDFlea
                      ehh, I must have messed up the file or something. I used NEO and the 1.8v adapter, but NEO is telling me the same thing. Any chance you'd have a look at the dump and fix it up? pretty please? https://drive.google.com/file/d/1-7I...ew?usp=sharing
                    • LEO037_2029_
                      BIOS_LEGEND
                      • Nov 2023
                      • 83
                      • Argentina
                      survivalbloke look i attach for you.
                      • survivalbloke
                        • Aug 2021
                        • 313
                        That flashed OK, thanks! Hopefully this resolves the initial problem.
                          • 22169
                          If it doesn`t work,and i don`t think it will try this one.Includes your DMI.
                          • survivalbloke
                            • Aug 2021
                            • 313
                            SMDFlea Yea, LEO's flash did not work. How did you know it wouldn't? I'll try yours right now and report back.
                            • survivalbloke
                              • Aug 2021
                              • 313
                              With that flash, it will power up for about 2 seconds, then go dead until the power button is pressed again. So that's definitely DIFFERENT than it was originally. I noticed I'm missing my 3.3 on P8 of the bios chiup.
                                • 22169
                                @LEO037_2029_ ​ did not delete the CAP header first.
                                • survivalbloke
                                  • Aug 2021
                                  • 313
                                  SMDFlea Should I just bail on this computer?
                                    • 22169
                                    You can try earlier bios versions if you want to but it seems like a hardware problem to me. To find earlier bios versions edit the version number in the download link. So 7wcn38ww , edit to 7wcn37ww ,36,35 and so on.Or,you can find some older versions in the 330S-15ARR thread https://www.badcaps.net/forum/troubl...r-330s_arr_v06
                                    • survivalbloke
                                      • Aug 2021
                                      • 313
                                      I appreciate it SMDFlea. I'm going to take your assumption and just move on from this job. Thanks!
                                      • to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                        by to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                        I have opened the laptop and identified the main BIOS chip...
                                        10-24-2025, 01:35 AM
                                      • Forest79
                                        by Forest79
                                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                        07-23-2023, 07:39 AM
                                      • userbtcku
                                        I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B
                                        by userbtcku
                                        I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B.
                                        Can anyone help me find the BIOS file for this laptop?
                                        This laptop is having trouble booting from a flash drive or SSD.
                                        I've updated the BIOS with a file downloaded from lenovo.com, but it still doesn't work.
                                        So I'm thinking of flashing it another way.
                                        11-19-2025, 02:18 AM
                                      • Jk KIM
                                        Lenovo Ideapad 5 15ITL05 Bios File extract
                                        by Jk KIM
                                        Hi
                                        I need to extract bin file from bios update file which downloaded at Lenovo web site.
                                        Pls extract bin file from exe file...
                                        I attached exe file!
                                        Thx!...
                                        02-03-2023, 07:40 AM
                                      • bob113313
                                        extract bios dump file from exe Lenovo amd ideapad 5 15alc05
                                        by bob113313
                                        first of all my apologies for my English (I don't speak it very well, I am French).
                                        I am trying to troubleshoot a lenovo ideapad 5 15alc05 ryzen 7 that boots but remains in black screen.
                                        I would like to know if anyone knows how to extract the .bin of bios from the exe published on the lenovo site. I have found several information on the internet but they don't work in my case. I think it's because it's an amd.
                                        I found some dump on the internet but I don't really trust it. I would like to make a clean bis from the official Lenovo file...
                                        12-10-2022, 05:16 AM
