Chromebook e100 2nd Gen
  • PycLaH
    • Feb 2022
    • 28
    Chromebook e100 2nd Gen - Bios enable Developer Mode and remove Managed by...
    I Have Chromebook e100 2nd Gen,
    Please can you enable Developer mode and remove managed by ... please
    mlb_serial_number: 1532022002872
    serial_number: PF2TKV5V
    model_name: Lenovo 100e Chromebook 2nd Gen
    mfg_date: 2021-04-19
  • petehall347
    • Jan 2015
    • 4427
    will it not go into Recovery Mode to start developer mode ?
    • PycLaH
      • Feb 2022
      • 28
      it will. by pressing esc+ refresh + power btn, but after Ctrl+D says , developer mode disabled !
      • petehall347
        • Jan 2015
        • 4427
        ok you should do powerwash after backing up and try again ..if it still wont go into developer mode make a memory stick at least 8gb with recovery files . you need the extension in chrome based browser . chromebook recovery . after that it will be a like a new chromebook . i have just done this for someone .
        • volinakis
          • Jan 2021
          • 2744
          • N/A
          after writing new bios reinstall from USB stick made with Chromebook Recovery Utility for your chromebook model
          • PycLaH
            • Feb 2022
            • 28
            Thank you ill try tmz at work Thank you very much !
            • gclagos0523
              • Sep 2021
              • 26
              • Philippines
              Need help also to enable developer mode for my Lenovo 100e Chromebook 2nd Gen AST, Developer Mode disabled
              BOARD Model: BM5988 v1.3
              SN: MP1WRB8Y
              Thank you..
              • volinakis
                • Jan 2021
                • 2744
                • N/A
                SN: MP1WRB8Y
                Thank you..
                try. reset or reinstall if reset doesn't do the trick. to enable developer mode you have to remove battery.
                • PycLaH
                  • Feb 2022
                  • 28
                  Thank you, worked fine !
                  • gclagos0523
                    • Sep 2021
                    • 26
                    • Philippines
                    Thank you but still cant enable developer mode
                    • volinakis
                      • Jan 2021
                      • 2744
                      • N/A
                      told you to REMOVE battery and power up only on ac adapter, read mrchromebox page.
