Looking for a working BIOS for GIGABYTE G5 KD laptop motherboard NH50HPMB-0D
  • dl1nn1u
    • May 2019
    • 6
    • Ukraine
    There are also markings on the motherboard
    6-71-N5HP0-D04
    SN/ 1TNH50HP000003054018
    P/N 6-77-NH50HP00-D04-5C#1GB1
    The problem is as follows
    The laptop turns on, there is no image or backlight, after a minute the fans turn on, there is no old BIOS dump, please help​
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    6-71-N5HP0-D04
    Try
    (always make a backup to get accurate bios )
    • dl1nn1u
      • May 2019
      • 6
      • Ukraine
      Originally posted by qayyum786
      Try
      I installed the firmware for the u52 chip and flashed the EС, the result is the same, if there are options I'll still wait. Thank you
      After pressing the button, the laptop turns on the keyboard backlight, it changes within 1 minute, and then the fans turn on to maximum, and after one minute the laptop turns off. There is no image on the display, there is no display backlight, there is also a reaction to the on and off button. Without RAM, the laptop behaves the same way, I'm surprised.
      Sound card, Realtek
      • dl1nn1u
        • May 2019
        • 6
        • Ukraine
        The dump is working, the problem was on the motherboard
        • abel_2290
          • Dec 2020
          • España
          Hello, I have the same problem, how do I solve it?
          • dl1nn1u
            • May 2019
            • 6
            • Ukraine
            The hub was damaged, replacing the hub solved the problem
            • meenen01
              • Mar 2016
              • 9
              Hi dI1nn1u
              Have the same problem - You say the Hub was damaged - what do you mean with replacing the HUB ????? - what part do you chnage ??? Thanks for answering
            • raizenn27
              • Jun 2011
              • 93
              • philippines
              good day i also have encounter same problem,maybe someone can fix or clean this dump thanks
            • raizenn27
              • Jun 2011
              • 93
              • philippines
              im sorry my bad
              here is the info
              GIGABYTE laptop
              G5 KD
              s/n SN22121J002323
              boardcode NH50HPMB-0D​
              issue encountered the unit was turning on but no display output..,and already tried the uploaded bios file and same result.hope still any solution may fix my old bin file can someone build or clean..thanks
              • hoaca388
                Badcaps
                • Jan 2022
                • 11181
                • Viet Nam
                G5 KD
                • meenen01
                  • Mar 2016
                  • 9
                  same problem
                  system starts - no picture - Keyboard leight turns on - after minute Fan runs maximum
                  GIGABYTE laptop
                  G5 KD
                  s/n SN1966932
                  • meenen01
                    • Mar 2016
                    • 9
                    Sorry wrong Sr.Nr.
                    This is the Bord Sr.Nr. 1TNH50HP1242545
                  • meenen01
                    • Mar 2016
                    • 9
                    here is the corrupted bios file
                    • meenen01
                      • Mar 2016
                      • 9
                      bump
                      • meenen01
                        • Mar 2016
                        • 9
                        bump
                        ​bump again. Any help please
                        Last edited by SMDFlea; 06-19-2024, 07:32 AM. Reason: bios deleted already posted it once
                        • noTurner
                          • Nov 2022
                          • 61
                          • Austria
                          Hello there, I've got a G5 KD with the i5-10300H and RTX 3060,
                          it turns on and shows the green LED for 3 seconds and then turns off immediately. Laptop is charging fine.
                          Anyone here who can help me out with this issue?
                        • peste
                          • Dec 2016
                          • 12246
                          • ROMANIA
                          post S/N, full name and model, motherboard model,etc.
                          read the forum rules..
                          https://www.badcaps.net/forum/troubl...ore-posting​
                          • glovecaps
                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                            by glovecaps
                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                            11-25-2024, 04:23 PM
                          • survivalbloke
                            Gigabyte motherboard missing CPU compatibility due to BIOS version being too low - proper way from here?
                            by survivalbloke
                            This job which came in is a Gigabyte B650M D3HP AX (rev. 1.0). It has BIOS version F1 currently, and the CPU installed is Ryzen 9 9900X, which according to the Gigaybte site, needs at least BIOS version F30. I don't have a supported CPU to install for the purpose of updating the BIOS. I have downloaded the BIOS from Gigabyte's website and unzipped the file "B650MD3HPAX.F32a". Can I just rename it to 'B650MD3HPAX.BIN' and flash it to the motherboard using neoprogrammer and my CH341A?...
                            09-16-2024, 04:06 PM
                          • ReeferMadness
                            Bios for Gigabyte GA-MA74GM-S2 desktop motherboard
                            by ReeferMadness
                            Can anyone post a complete bios dump for a Gigabyte GA-MA74GM-S2 Rev 1.0 desktop motherboard please?
                            I have a dead motherboard - with no obvious signs of damage which I would like to save from scrap
                            Many thanks for any help
                            01-17-2025, 10:55 AM
                          • oragano
                            ASUS ex-b250-V7 motherboard bios corrupted - by me
                            by oragano
                            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                            10-17-2024, 02:53 AM
                          • AkaBukai
                            Is it okay to flash stock bios onto the motherboard's BIOS?
                            by AkaBukai
                            Hi there,
                            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                            The little LED on the power button is flashing slowly and nothing happen.
                            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                            So I decided to flash the BIOS using a cheap programmer.
                            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                            I also...
                            12-19-2024, 12:15 PM
