Looking for a working BIOS for GIGABYTE G5 KD laptop motherboard NH50HPMB-0D
  • dl1nn1u
    • May 2019
    • 6
    • Ukraine
    There are also markings on the motherboard
    6-71-N5HP0-D04
    SN/ 1TNH50HP000003054018
    P/N 6-77-NH50HP00-D04-5C#1GB1
    The problem is as follows
    The laptop turns on, there is no image or backlight, after a minute the fans turn on, there is no old BIOS dump, please help​
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    6-71-N5HP0-D04
    Try
    (always make a backup to get accurate bios )
    • dl1nn1u
      • May 2019
      • 6
      • Ukraine
      Originally posted by qayyum786
      Try
      I installed the firmware for the u52 chip and flashed the EС, the result is the same, if there are options I'll still wait. Thank you
      After pressing the button, the laptop turns on the keyboard backlight, it changes within 1 minute, and then the fans turn on to maximum, and after one minute the laptop turns off. There is no image on the display, there is no display backlight, there is also a reaction to the on and off button. Without RAM, the laptop behaves the same way, I'm surprised.
      Sound card, Realtek
      • dl1nn1u
        • May 2019
        • 6
        • Ukraine
        The dump is working, the problem was on the motherboard
        • abel_2290
          • Dec 2020
          • España
          Hello, I have the same problem, how do I solve it?
          • dl1nn1u
            • May 2019
            • 6
            • Ukraine
            The hub was damaged, replacing the hub solved the problem
            • meenen01
              • Mar 2016
              • 9
              Hi dI1nn1u
              Have the same problem - You say the Hub was damaged - what do you mean with replacing the HUB ????? - what part do you chnage ??? Thanks for answering
            • raizenn27
              • Jun 2011
              • 94
              • philippines
              good day i also have encounter same problem,maybe someone can fix or clean this dump thanks
            • raizenn27
              • Jun 2011
              • 94
              • philippines
              im sorry my bad
              here is the info
              GIGABYTE laptop
              G5 KD
              s/n SN22121J002323
              boardcode NH50HPMB-0D​
              issue encountered the unit was turning on but no display output..,and already tried the uploaded bios file and same result.hope still any solution may fix my old bin file can someone build or clean..thanks
              • hoaca388
                Badcaps
                • Jan 2022
                • 11713
                G5 KD
                • meenen01
                  • Mar 2016
                  • 9
                  same problem
                  system starts - no picture - Keyboard leight turns on - after minute Fan runs maximum
                  GIGABYTE laptop
                  G5 KD
                  s/n SN1966932
                  • meenen01
                    • Mar 2016
                    • 9
                    Sorry wrong Sr.Nr.
                    This is the Bord Sr.Nr. 1TNH50HP1242545
                  • meenen01
                    • Mar 2016
                    • 9
                    here is the corrupted bios file
                    • meenen01
                      • Mar 2016
                      • 9
                      bump
                      • meenen01
                        • Mar 2016
                        • 9
                        bump
                        ​bump again. Any help please
                        Last edited by SMDFlea; 06-19-2024, 07:32 AM. Reason: bios deleted already posted it once
                        • noTurner
                          • Nov 2022
                          • 61
                          • Austria
                          Hello there, I've got a G5 KD with the i5-10300H and RTX 3060,
                          it turns on and shows the green LED for 3 seconds and then turns off immediately. Laptop is charging fine.
                          Anyone here who can help me out with this issue?
                        • peste
                          • Dec 2016
                          • 12748
                          • ROMANIA
                          post S/N, full name and model, motherboard model,etc.
                          read the forum rules..
                          https://www.badcaps.net/forum/troubl...ore-posting​
