Panasonic CF-19rdt5a1m mk4 bios
  • Pilotow 67
    • Apr 2024
    • Poland
    Hello !!
    i have a problem with the bios to a Panasonic CF-19
    model:Cf-19rdt5a1m mk4
    serial:1CKSA49802
    with faulty bios chip MX25L6445e and I need a dump for this laptop model !!
    Thanks​
  • graziano61
    • Jul 2016
    • 20
    • Italy
    Ciao a tutti.
    Ho un panasonic CF-19KHR02NT MK4 S/N AB0123456789 9KKSA24718 con una password sul BIOS e anche sull'HDD.
    Qualcuno può aiutarmi a recuperarlo? Dump BIOS completo allegato. Grazie per tutto
    [MOD EDIT] English translation Hi everyone. I have a panasonic CF-19KHR02NT MK4 S/N AB0123456789 9KKSA24718 with a password on the BIOS and also on the HDD. Can anyone help me recover it? Complete BIOS dump attached. Thanks for all​
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • grimacelord
      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
      by grimacelord
      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
      Motherboard model number: DA0PAMB46A1 REV: A
      Secondary motherboard model number: 0PAB
      SKU: 685K4UA
      Serial number is: 5CD3223BJP
      Recently reflashed this laptop with latest BIOS and once...
      05-07-2024, 08:06 AM
    • DynaxSC
      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
      by DynaxSC
      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
      11-06-2022, 05:22 PM
    • TacticalFahrrad
      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
      by TacticalFahrrad
      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
      06-30-2025, 04:09 AM
