Bios repair No keyboard Backlight Vivobook m3401qa
  • guyandpit
    • Oct 2021
    • 81
    • Philippines
    bios repair asus vivobook pro 14 m3401qa
    UPDATE(new extracted bios):
    eed help to repair my bios for asus vivobook pro 14 m3401q,the laptop is running smooth but the keyboard backlit is missing, i ried to test good working keyboard with light still no light. it was working before. pls help to solve this issue. attached new extracted bios from the board
    Thank you in advance and more power
    details:
    cpu ryzen 5 uma graphics
    model: m3401q
    sn: mbn0cx367924478​
  • minhdigital
    • Nov 2022
    • 762
    • Vietnam
    details:
    model: m3401q
    Send to you
    • guyandpit
      • Oct 2021
      • 81
      • Philippines
      Originally posted by minhdigital
      Send to you
      i tried this but still no keyboard light and fingerprint not working. Thank you
        • 21403
        Bios + DMI.
        https://www.badcaps.net/forum/troubl...24#post1622424
        4.4. Asus
        With these tools you can add DMI information, add a MAC address to older generation Asus boards and fix the keyboard backlight not working on newer generation boards.
        • guyandpit
          • Oct 2021
          • 81
          • Philippines
          Originally posted by SMDFlea
          Bios + DMI.
          4.4. Asus
          hi friend, im going to use Hex editing software and Macro script apply the bios+DMI.zip? sorry im not good in program but im willing to learn. thank you for guidance.
            • 21403
            The Macro script is not what you want, you can use the Asus block transmit tool if the keyboard backlight isn`t working. I have already added the DMI from your backup to the new one.
            Click image for larger version  Name:	Capture.jpg Views:	0 Size:	24.2 KB ID:	3249957
            • guyandpit
              • Oct 2021
              • 81
              • Philippines
              Thank you friend i will try these bios later
              • guyandpit
                • Oct 2021
                • 81
                • Philippines
                Bios + DMI.
                4.4. Asus
                friend backlight still not working thank you
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  did you press FN+F7 key 3 to 4 time
                  • guyandpit
                    • Oct 2021
                    • 81
                    • Philippines
                    yes nothing happen
                    • Luke11037
                      ASUS Vivobook 14 Pro M3401QA BIOS Needed
                      by Luke11037
                      Trying to recover the BIOS on a asus vivobook 14 M3401QA as i believe it to be corrupted however I am struggling to make a recovered bios image myself. Attached is the bios dump from the laptop.
                      Laptop specs:
                      CPU - Ryzen 5 5600H
                      Model - M3401QA-KM065W
                      SN - MBN0CX33Y50447B...
                      05-18-2024, 06:21 AM
                    • NotEnough
                      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                      by NotEnough
                      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                      What I've Tried So Far:
                      • Reseated the cables.
                      • Reinstalled AWCC and AlienFX services.
                      • Attempted BIOS downgrade but no improvement.
                      • Inspected ribbon cables for damage.
                      • Explored the possibility of BIOS or
                      10-19-2024, 01:34 AM
                    • greelidd
                      K6604J Vivobook RTX 4070 BIOS Dump Request
                      by greelidd
                      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                      09-01-2025, 06:14 PM
                    • zlr8r
                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                      by zlr8r
                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                      cheers
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                      Attached;
                      1. My saved bios using a programmer
                      2. Dells Bios updater .exe (v1.16)
                      3. Dells Bios recovery file
                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                      5. Image of ME...
                      12-18-2023, 03:08 PM
                    • zarabota
                      Acer Aspire A717-71G - problem BIOS with keyboard
                      by zarabota
                      I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
                      However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
                      09-03-2025, 01:58 AM
