Alienware X17 R2 (LA-L613P) need BIOS dump or BIOS extract
  • Svyatpro
    • May 2016
    • 12
    • Ukraine
    Hello folks.
    I have Alienware X17 R2 (LA-L613P) with broken BIOS after unsuccessful BIOS update.
    Dell_PFS_Extract cannot extract BIOS from bios update.
    Here is my dump.
    • 21145
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Svyatpro
      • May 2016
      • 12
      • Ukraine
      Dell Alienware X17 R2
      ST: G9566M3
      Compal LA-L631P Rev 2.0
        • 21145
        ST: G9566M3
        try this one
        • Svyatpro
          • May 2016
          • 12
          • Ukraine
          Thanks. But it still doesn't work. It splashes 2 red 1 blue lights on power button.
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            Try
            if no luck than disconnect the battery, and other all power sources hold the power button down for 30 to 60 seconds, re-connect the battery and then try turning it on
            • Svyatpro
              • May 2016
              • 12
              • Ukraine
              Originally posted by qayyum786
              Try
              Thanks for your efforts but it doesn't even turn on with this BIOS image. 3 red 5 blue
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                Did you disconnect the battery, and other all power sources hold the power button down for 30 to 60 seconds, re-connect the battery and then try to turn on
                • Svyatpro
                  • May 2016
                  • 12
                  • Ukraine
                  Sure I tried
                  • zzduczz
                    • Mar 2014
                    • 31
                    • viet nam
                    TAG:9HQXJR3
                    Please help me rebuild it.
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      TAG:9HQXJR3
                      Service Tag: 9HQXJR3
                      Try
                      • zzduczz
                        • Mar 2014
                        • 31
                        • viet nam
                        Try
                        working 100% thank you very much
                        • trunguntilyou
                          • Aug 2022
                          • 329
                          • Vietnam
                          please help me! Full power supply, no image
                          st:51F12T3
                          • spacez
                            • Nov 2023
                            • 54
                            • FR
                            HELLO i need to rebuild bios file . corrupted . for my Alienware X17 R2
                            ST: GSX62T3
                            Compal LA-L631P Rev 2.0.
                            THANKS ​
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              ST: GSX62T3
                              THANKS ​
                              dmi and clean me region please give feedback
                              • chkintl93
                                • Jun 2019
                                • 47
                                • usa
                                Hi Can someone help remove the bios password of dell Alienware X17 R2?
                                ST: GHRFMN3
                                EX: 36902621183
                                Compal LA-L631P
                                Thank you for the help
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • drux
                                  Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                  by drux
                                  I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                  Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                  These models have AMI/Aptio BIOS.
                                  Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                  11-03-2024, 01:18 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • haitham sharabati
                                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                  💀 Problem:😅
                                  - Device shows “Administrator Password”...
                                  08-07-2025, 04:54 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
