Lenovo Thinkpad Ec Pwd Bypass
  • rediii
    h???, spurrrn
    • Mar 2018
    • 501
    • somewhere in europe
    #481
    Originally posted by Usering
    The old nvram patch method no longer works on the new updated generation, I said it can be erased and reset via new patch, because the code is also saved on npcx998.
    you can reset the password via editing the main bios nvram region activating mpm. there are alot of threads on this forum. pls lets concentrate on thinkpads only here.
    • Usering
      • Sep 2024
      • 51
      Yes, just a question and a note, since the new generation of HP G9 G10 uses main BIOS to crack the BIOS on npcx998, so we have hope for a way one day on thinkpad, regarding the link you shared with me yesterday, there is a person with us in the forum and in the current topic, who succeeded in unlocking the t14s gen 2, can he share his ideas with us? Thanks.
      • Usering
        • Sep 2024
        • 51
        https://www.badcaps.net/forum/troubl...nkpad-t14-gen2
        • rediii
          h???, spurrrn
          • Mar 2018
          • 501
          #484
          1. hp architecture =/= lenovo architecture (even if the sio is the same)
          2. no, he won't tell us even if he managed to unlock it
          wait 2.: it was/is mmccomputer, who wrote this in the thread (https://www.badcaps.net/forum/troubl...nkpad-t14-gen2). this guy just wrote yesterday (https://www.badcaps.net/forum/troubl...12#post3494795), that he shipped these devices to algeria for unlocking service. sooo...
          • lktech
            • Jan 2021
            • 39
            • algeria
            #485
            About some motherboards have mec15xx and npcx9xx there is a solution here in Algeria without hardware or software i confirm
            • mmccomputer
              • 75
              • France
              #486
              to make things clear, the solution I talked about in the thread ''Unlock SVPLenovo Thinkpad T14 Gen2"
              is different from the solution of the guy from Algeria
              the first is functional on certain Mec1503 (and I cannot share it because I do not have authorization of its owner and it requires a hardware modification)
              the second is functional and concerns mec15xx mec17xx (but not all) and some npcx9xx and it cost me around 100 euros (transport and service)
                • 22030
                I`ll just remind everyone of the rules https://www.badcaps.net/forum/troubl...before-posting
                • Mahesa09
                  • Nov 2021
                  • 67
                  • jakarta
                  #488
                  hy brother, Can the L490 password be bypassed via EC? IT8227E-256-AX_LQFP128_14X14
                  • Zombi3002
                    • Oct 2024
                    • 3
                    I want to try this method on a thinkpad T480.
                    J5 is available for this, should I put a resistor in series to limit current when shorting to ground?
                    • anhbanxoi
                      • Sep 2021
                      • 180
                      • VN
                      #490
                      No need, just short the LPC_AD0:3 to ground.
                      • Zombi3002
                        • Oct 2024
                        • 3
                        Alright, thank you for the fast response.
                        • thinkpadg6
                          • Nov 2024
                          • 5
                          I have a t14s gen mec 1663. It has a supervisor password. Pressing just enter doesnt let me in view bios in general user. Instead it says i have 2 tries left. I have the jumper installed as per the image provided. However pressing the switch during boot doesnt get me into bios. After several tries it go to a screen saying bios self heal process. Then i try again.
                          any help appreciated.
                          • thinkpadg6
                            • Nov 2024
                            • 5
                            Actually it must be the auora of this group. Since I posted next try worked.
                            Now i have invalid machine, type serial and board serial.
                            Any idea how to fix that.
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 501
                              #494
                              https://www.badcaps.net/forum/troubl...r-bootable-usb
                              • thinkpadg6
                                • Nov 2024
                                • 5
                                Thank you. Will check there.
                                • Zombi3002
                                  • Oct 2024
                                  • 3
                                  Originally posted by Maxpower3
                                  Hello everyone.
                                  Here is the bypass solution for several Lenovo ECs.
                                  This has worked on many ECs.
                                  Only works if password is contained in EC
                                  I succeeded on many models
                                  https://www.badcaps.net/forum/troubl...86#post3217086
                                  https://www.youtube.com/channel/UCeF...t_adKcguvynjeA
                                  I shorten the LPC bus, with the LAD0:3 and Gnd.
                                  you can use the dedicated ports where you connect directly to the track.
                                  (Be careful, resistors may be missing on the path)
                                  look at the diagrams
                                  example x390 npce388
                                  The communication being cut off, corrupted,
                                  it cannot read information contained in EC and therefore continues.
                                  then simply clean by rewriting after access.
                                  Don't save with F10, just clean Pwd with enter twice.
                                  If the serial, uuid etc. information is corrupted, you are saving the wrong information
                                  Like the old way with sda/scl.
                                  The method is delicate, there is always a risk of bricking or try failed.
                                  ITE and Nuvoton is easy, Mec16 is more delicate (many try necessary).
                                  Timing is important
                                  watch videos to understand
                                  works on Mec1633 / Mec1653 / Mec1663 / IT8186VG / IT5261VG / NPCE68B / NCPE288/388 and surely others
                                  but my tests failed with the Mec1503
                                  The LPC bus is no longer used, it has been replaced by eSPI
                                  Attached some connection diagrams for tested models
                                  Edit
                                  EC PWD eeprom location
                                  NCPE68B
                                  Dmi start from 0x5C120 and 0x5D120
                                  Pwd 0x5C420 - 0x5C56F and 0x5D420 - 0x5D56F replace with 00
                                  NCPE288/388
                                  Dmi start from 0x30000
                                  Pwd
                                  0x36000 - 0x3604F
                                  0x36080 - 0x360CF
                                  0x36100 - 0x3614F
                                  0x36180 - 0x361CF
                                  0x36200 - 0x3624F
                                  0x36280 - 0x362CF
                                  0x36300 - 0x3634F
                                  0x36380 - 0x363CF
                                  0x36400 - 0x3644F
                                  0x36480 - 0x364CF
                                  0x36500 - 0x3654F
                                  0x36580 - 0x365CF
                                  0x36600 - 0x3664F
                                  0x36680 - 0x366CF
                                  replace with 00
                                  Mec1663 Dmi start from 0x00
                                  Pwd 0x300 - 0x34F replace with FF
                                  search for this shape
                                  Click image for larger version Name:	ec pwd.png Views:	0 Size:	310.0 KB ID:	3237274
                                  Another t480 unlocked with this method, it took me like 4 attempts.
                                  Also, I used some electric tape to isolate the other jumper contacts at J5. This helped me quite a bit with aiming (the contacts are kinda small) and timing.
                                  This t480 can now be turned into the little beast that is supposed to be. Without this method and this manual this wouldn't have been possible, so thank you and everyone else very much for making this possible!
                                  • cgtec
                                    • Feb 2014
                                    • 56
                                    • France
                                    #497
                                    Has anyone tried the segger programmer before?
                                    Is it true that Segger programmer can program MEC1503, MEC1723 chip?
                                    thanks
                                    segger programing CHIP USE SPI
                                    • Andreasbest
                                      • Aug 2014
                                      • 1196
                                      • Hellas ( Greece )
                                      #498
                                      [QUOTE=cgtec;n3506745]
                                      segger programing CHIP USE SPI [/QUOT
                                      Segger claims all their flashers, except the Segger one, supports Mec1503
                                      Not sure if i miss something here.
                                      https://www.segger.com/supported-dev...rochip/mec15xx
                                      • Sr_Osorio
                                        Frying chicken
                                        • Oct 2024
                                        • Brazil
                                        #499
                                        Hello, could someone help me with bypass to my Thinkpad L390 Model: 20NSS2GF00 - NPCE288GA0DX?
                                        • shiyab
                                          • Sep 2023
                                          • 1626
                                          • india
                                          #500
                                          post ec bios and snid
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
