Lenovo Thinkpad Ec Pwd Bypass
  • black0hackers
    • Jul 2020
    • 367
    i have try on T14 G2 with mec1503 but not done
    • Patrik Vilja
      • Apr 2024
      • 7
      • Sverige
      #42
      Intresting..
      So, to be able todo the eez on 17xx mcu, the decoupling cap is needed..?
      Am im thinking right...?
      Someone?
      • Patrik Vilja
        • Apr 2024
        • 7
        • Sverige
        #43
        • kitor
          • Apr 2019
          • 43
          • Poland
          #44
          What are you trying to do? What decoupling caps? Where did you get 5v and 1.8v?
          For LPC you short data pin(s) to ground, not up...
          • Patrik Vilja
            • Apr 2024
            • 7
            • Sverige
            #45
            My mec1723 has no lpc, it has espi.. somewhat digitalized protocol, compared to lpc, thats more analog...
            i belive Therese error checking on espi, and not lpc...
            (Confirm?)
            What Im thinking tho, if you remove the bat and cmos bat, hold powerbutton 20 sec, the mcu starts an bios restore, event svp data, defualts all settings.. after that, comp boots, and you get an error message, smt bout reading back conf info..
            As i beliveit here, the SVP, Bios password, area thats usualy not writeable is open..
            If ppl with 15 and 17 gen mec try and bug there..?
            If its only reading conf, back to mec, svp, settings and so on, this makes it easier and less prone to read wrong data, so you not corrupt and destroy your bios...
            Mening, you wont be able to corrupt mec bios, only config and settings.. (cmos-rst)
            and could maybe this also work with undervoltage glitching..?
            and UV, writes mostly 0. And OV(Overvoltage) 1..?
            its bettet to be an 0 then an 1 that starts everything, id say.. :p
            Question..
            Does mec16xx read from flash Every boot, and what does it read? (Svp pass
            Is that info stored on external efi chip, or stored inside the mec mcu?
            Or does 15 to 17 mec controllers read the bios conf and data same, or only the change in LPC or ESPI?
            • didouche1200
              • Oct 2016
              • 357
              • 82679911441
              #46
              i have thinkpad t14s moterboard nm-c891 with password please help me
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1226
                • France
                #47
                try one wire (lad0-3) with Gnd
                wait for the backlight,before logo.wait 1-2 sec with contact ,release and press f1 to enter setup
                errors can occur
                EC can be corrupted if you save wrong info
                Clear supervisor password with twice blank
                and manager with twice blank password
                Clear security chip too
                After just Ctrl alt del and try​
                if Mec need many tries
                Click image for larger version  Name:	T14S X13 .jpg Views:	0 Size:	1.31 MB ID:	3250062
                • milanTT
                  • Dec 2015
                  • Slovakia
                  #48
                  Maxpower very much thanks for this simple method, today I was able to remove system management password combined with predesktop authentication with help of one microswitch on Thinkpad T490 NM-B901 MEC1633
                  • khaledmosa99
                    • 75
                    • egypt
                    #49
                    Originally posted by danito
                    Try
                    thank you sair work like charm with pad num 3 many thanks to you and maxpower
                    • imranromi
                      • Jan 2015
                      • 1288
                      • Pakistan
                      #50
                      Can you tell which Ec chip use your board?
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        #51
                        • khaledmosa99
                          • 75
                          • egypt
                          #52
                          Yes sure NPCX897KA0BX
                          • miansh621
                            Banned
                            • May 2022
                            • 133
                            • pakistan
                            #53
                            Can u mention which points you use
                            • didouche1200
                              • Oct 2016
                              • 357
                              • 82679911441
                              #54
                              thanks work for me
                              • didouche1200
                                • Oct 2016
                                • 357
                                • 82679911441
                                #55
                                Where can I find lpc line in thinkpad t14s gen 2 nm-d361
                                • CraterM
                                  • Mar 2018
                                  • 178
                                  • Moldova
                                  #56
                                  In the galaxy. Only search!
                                  • bigboots
                                    • Mar 2019
                                    • 43
                                    #57
                                    Has anyone tried this on a T14 Gen 3?
                                    • nistel
                                      • Aug 2014
                                      • 33
                                      • Bulgaria
                                      #58
                                      I have some progress with T490 and MEC1663. Shorted LPC_AD0 to ground and sometimes i manage to get EAIA error 0187 and i got into BIOS with only 2 tabs - Config and Date/Time. Tried many many times with AD1,AD2,AD3
                                      Am i missing something?
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1226
                                        • France
                                        #59
                                        This happens to me too,
                                        change the timing and start earlier just before backlight and stays short for less time.
                                        Mec16 is difficult
                                        many many tries
                                        • azanwaqas771
                                          • Feb 2019
                                          • 48
                                          • Pakistan
                                          #60
                                          hi any one can onlock P15 Gen 1 NM-C651
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
