Lenovo Thinkpad Ec Pwd Bypass
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1226
    • France
    Hello everyone.
    Here is the bypass solution for several Lenovo ECs.
    This has worked on many ECs.
    Only works if password is contained in EC
    I succeeded on many models
    https://www.badcaps.net/forum/troubl...86#post3217086
    https://www.youtube.com/channel/UCeF...t_adKcguvynjeA
    I shorten the LPC bus, with the LAD0:3 and Gnd.
    you can use the dedicated ports where you connect directly to the track.
    (Be careful, resistors may be missing on the path)
    look at the diagrams
    example x390 npce388
    The communication being cut off, corrupted,
    it cannot read information contained in EC and therefore continues.
    then simply clean by rewriting after access.
    Don't save with F10, just clean Pwd with enter twice.
    If the serial, uuid etc. information is corrupted, you are saving the wrong information
    Like the old way with sda/scl.
    The method is delicate, there is always a risk of bricking or try failed.
    ITE and Nuvoton is easy, Mec16 is more delicate (many try necessary).
    Timing is important
    watch videos to understand
    works on Mec1633 / Mec1653 / Mec1663 / IT8186VG / IT5261VG / NPCE68B / NCPE288/388 and surely others
    but my tests failed with the Mec1503
    The LPC bus is no longer used, it has been replaced by eSPI
    Attached some connection diagrams for tested models
    Edit
    EC PWD eeprom location
    NCPE68B
    Dmi start from 0x5C120 and 0x5D120
    Pwd 0x5C420 - 0x5C56F and 0x5D420 - 0x5D56F replace with 00
    NCPE288/388
    Dmi start from 0x30000
    Pwd
    0x36000 - 0x3604F
    0x36080 - 0x360CF
    0x36100 - 0x3614F
    0x36180 - 0x361CF
    0x36200 - 0x3624F
    0x36280 - 0x362CF
    0x36300 - 0x3634F
    0x36380 - 0x363CF
    0x36400 - 0x3644F
    0x36480 - 0x364CF
    0x36500 - 0x3654F
    0x36580 - 0x365CF
    0x36600 - 0x3664F
    0x36680 - 0x366CF
    replace with 00
    Mec1663 Dmi start from 0x00
    Pwd 0x300 - 0x34F replace with FF
    search for this shape
    Click image for larger version  Name:	ec pwd.png Views:	0 Size:	310.0 KB ID:	3237274
  • volinakis
    • Jan 2021
    • 2728
    • N/A
    Thanks for sharing and as always good job!
    • CraterM
      • Mar 2018
      • 178
      • Moldova
      Thank you MxP
      Yesterday I discovered what you posted, I immediately realized the solution and thought straight to Mec1503
      What is the difference between eSPI and LPC? Only speed?
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1226
        • France
        I don't know yet, I haven't looked closely yet. the post is also there for research
        • CraterM
          • Mar 2018
          • 178
          • Moldova
          On the diagram, communication is identical!
          Click image for larger version  Name:	espi.jpg Views:	3 Size:	79.5 KB ID:	3237276
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            During my tests, freezing and overconsumption of the PC.
            need to cut off the power
            I couldn't do many tests because I don't have a lot of Mec15,
            like Ncpx, I couldn't test
            • CraterM
              • Mar 2018
              • 178
              • Moldova
              I don't have a 1503 or ncpx at the moment.
              Frezing in logo? or before logo?​
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1226
                • France
                as soon as you touch it's over
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1226
                  • France
                  Hello, Please, Thanks Lost in space .....?
                  it's over DXE
                  • RethoricalCheese
                    • Mar 2013
                    • 1518
                    • Estonia
                    Like I said, tested on P53 and P1 gen 2, thus works fine on ncpx.
                    Which model has mec1503?
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1226
                      • France
                      T14S gen 2
                      https://www.badcaps.net/forum/troubl...m-d362-rev-3-0
                      thank you for your well feedback
                      • CraterM
                        • Mar 2018
                        • 178
                        • Moldova
                        Working because use LPC.
                        But these use eSPI
                        Lenovo T16 Gen.1 NPCX997
                        Lenovo L15 Gen.3 NPCX997
                        ThinkPad X1 Yoga 6th gen MEC1503
                        X1 Carbon 10th / X1 Yoga 7th gen - MEC1723​
                        • miansh621
                          Banned
                          • May 2022
                          • 133
                          • pakistan
                          which point you short circuit to reset the password
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1226
                            • France
                            afterwards people ask me why I don't want to share.
                            Damn, make an effort and look for everything indicated.​
                            stop private messages without any form of politeness too
                            • miansh621
                              Banned
                              • May 2022
                              • 133
                              • pakistan
                              ok sorry bro
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1226
                                • France
                                find schematics or boardview
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1518
                                  • Estonia
                                  But these use eSPI
                                  I've got a few ones with NPCX997. Will try them in a couple of days.
                                  P1 Gen 4/5
                                  P16s Gen 1
                                  Not sure if I have any MEC1503. Shall see.
                                  • CraterM
                                    • Mar 2018
                                    • 178
                                    • Moldova
                                    P1 Gen 4/5
                                    P16s Gen 1
                                    If you can do it on NPCX997, I think it works on 1503
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1226
                                      • France
                                      NM B911 E490 It8227 (not tested)
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1226
                                        • France
                                        T480S NM-B471
                                        Tested Ok
                                        Cliquez sur l'image pour la voir en taille r?elle   Nom : 		T480s Nm-B471.jpg  Affichages :	0  Taille :		473,9 Ko  ID : 			3238407
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
