dv7-6130ez no display bios
  • layad
    • Nov 2011
    • 249
    hi there
    anyone can help me fixing an intel hp dv7-6130ez laptop , two caps lock led flashing
    thanks
    • 22293
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • layad
      • Nov 2011
      • 249
      i could not find the motherboard model number , serial number is 5ch1381t8w
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        bios extracted from update for HP Pavilion dv7-6130ez..
        DMI 180000 - 1800FF​
        • layad
          • Nov 2011
          • 249
          worked thanks , after next boot gone back to no display and two times led flashing
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            change your bios chip..
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • evilgenius31
              Zephyrus G14 GA401QH-211 Bios missing serial number
              by evilgenius31
              Hi All,
              I was told to post my corrupted bios dump here. My Zephyrus G14 GA401QH-211 is missing the serial number in the bios. NVME drives can't be detected by the bios either. The bios version is 410.
              Serial: M4NRKD01530915H
              Thanks in advance!...
              11-10-2025, 03:58 PM
            • Friend33
              Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
              by Friend33
              I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
              06-16-2024, 03:13 PM
            • lanovey
              SF314-41 BIOS without internal display
              by lanovey
              Hello there,
              I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
              I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
              06-13-2025, 02:38 AM
            • acerRI
              Gigabyte MB missing serial number in BIOS
              by acerRI
              We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
              PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
              I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
              Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
              Any help will be...
              09-23-2025, 05:26 AM
