Hp Probook 440 G10 Bios Needed
  • lapoype
    • Jun 2025
    • 3
    • France
    #61
    Originally posted by lapfix
    You must upload your bios
    Thank you, but where to download the bios that corresponds to the pc and what is the procedure thank you in advance
    • lapfix
      • Mar 2020
      • 2756
      • my workshop
      #62
      You must have hot air and programmer.
      desolder your bios chip from your motherboard..read it with your programmer and upload it here..somone Will help you
      • lapoype
        • Jun 2025
        • 3
        • France
        #63
        Ok I thought it was simpler than that, I'm not good enough to do this kind of manipulation, sorry for the inconvenience
        • hpboy
          • Jan 2021
          • 53
          Originally posted by hpboy
          Hi All,
          I have a HP 440 G10 with a bios admin passsword which I would like to remove. I have tried the rex98 files in post 43 (both main and EC) but after install all I see is a flashing caps lock (no image, nothing else). I have also tried just the BIOS (reverting EC back to the original) but this also does not work.
          Please could someone help me remove the Bios admin password? I have posted the original backups below:
          Serial - 5CD40132ZTF
          Prod - 717Q4AV
          Model - HP Probook 440 G10
          I have now tried manually removing the values from "NvramActive" section but that also has not worked. Anyone please help?
          • volinakis
            • Jan 2021
            • 2872
            • N/A
            #65
            rex98 files should work, try again and check soldering. You have to wait 3-5 minutes until you'll get image, it will make a bios update (downgrade, infact) and then enter in mpm. Press F10 and reset bios factory defaults then use BCU to write your DMI.
            • hpboy
              • Jan 2021
              • 53
              volinakis - thank you very much. My soldering was excellent... however, my patience was terrible 😁 I waited longer this time and after 3 minutes, the files worked like a charm!
              rex98 - thank you for the files, really apprecaite it
              • volinakis
                • Jan 2021
                • 2872
                • N/A
                #67
                you are welcome.
                • omar55
                  • Dec 2021
                  • 6
                  • mexico
                  #68
                  Can you help me to Disable Absolute? please
                  ProBook 440 G10
                  serial #5CD3474QB8
                  apparently has a MdM profile
                  • TCN06
                    • Jun 2025
                    • 5
                    • France
                    #69
                    I'm following this thread with interest because I bought one of their PCs, an HP 440 G10, from a company. Unfortunately, it's neither formatted nor accessible (it has a Windows password and a BIOS password).
                    I'm stuck: while disassembling and reassembling PCs isn't an issue for me, soldering is a major obstacle. I paid €250 for this computer, and I'm quite disappointed at the thought of having lost that money.
                    I've seen methods online talking about short-circuiting the chip with tweezers or similar, by choosing the right pins. However, I have no idea how to identify the correct ones. Do you know?
                    Are there any solder-free solutions to resolve this problem? Or should I just accept that I've lost €250 and my time, and simply throw the PC away?
                    Bonjour,
                    Je suis ce fil de discussion avec intérêt car j'ai acheté à une entreprise un de leurs PC, un HP 440 G10. Malheureusement, il n'est ni formaté, ni accessible (il y a un mot de passe Windows et un mot de passe BIOS).
                    Je me retrouve bloqué : si démonter et remonter des PC ne me pose aucun problème, la soudure est un obstacle majeur pour moi. J'ai payé cet ordinateur 250 €, et je suis assez déçu à l'idée d'avoir perdu cette somme.
                    J'ai vu sur internet des méthodes parlant de court-circuiter la puce avec une pince à épiler ou autre, en choisissant les bonnes bornes. Cependant, je ne sais pas du tout comment identifier les bonnes bornes. Sauriez-vous me renseigner ?
                    Existe-t-il des solutions sans soudure pour résoudre ce problème ? Ou dois-je me résigner à avoir perdu 250 € et du temps, et simplement jeter le PC ?
                    • peste
                      • Dec 2016
                      • 13347
                      • ROMANIA
                      #70
                      Bonjour,
                      The bios chip must be unsoldered from the board before writing or reading..
                      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                      solder wires between the programmer and the bios chip..
                      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                      • TCN06
                        • Jun 2025
                        • 5
                        • France
                        #71
                        Thanks for your reply.
                        Can I get a low-end SPI programmer like this one (https://a.aliexpress.com/_mtez5hp)?
                        Do I need to solder the BIOS chip's pins onto this programmer? And if so, which pin goes to which point? I'm trying to understand. If I see it's too complicated for me, I'll give up.
                        Thanks again.
                        Merci pour ta réponse.
                        Un programmateur SPI, je peux en prendre un bas de gamme comme celui-ci (https://a.aliexpress.com/_mtez5hp) ?
                        Il faut que je soude les broches de la puce BIOS sur ce programmateur ? Et si oui, quelle broche va sur quel point ? J'essaie de comprendre. Si je vois que c'est trop compliqué pour moi, je laisserai tomber.
                        Merci encore.
                        • lapfix
                          • Mar 2020
                          • 2756
                          • my workshop
                          #72
                          Thanks again.
                          Merci encore.
                          Better you choose a RT809F + a hot air.
                          You can find many videos at youtube explain how : justtype some words key like
                          Desolder bios , how to use rt809 , how to read bios ..etc..
                          • TCN06
                            • Jun 2025
                            • 5
                            • France
                            #73
                            Great! I have a "DIY enthusiast" friend who owns the device available via this link:
                            https://amzn.eu/d/bMrjPPi. He's asking me for the chip reference to program (for voltage, bus, etc.). He'd like to know if, with his programmer and even his clip, he could work on it using the information from post 43. Thanks again for everything, by the way!
                            Super ! J'ai un ami "bidouilleur" qui possède l'appareil disponible via ce lien:
                            https://amzn.eu/d/bMrjPPi. Il me demande la référence de la puce à programmer (pour le voltage, le bus, etc.). Il souhaiterait savoir si, avec son programmateur et même sa pince, il pourrait intervenir grâce aux informations du post 43. Encore un grand merci pour tout, d'ailleurs !
                            • connorh315
                              • Jun 2025
                              • England
                              #74
                              What version(s) of the BIOS still only require the main "SPI ROM" to be patched rather than both chips and how would I determine whether my BIOS is that version?
                              Also how do you guys go about unlocking these BIOSs, is there a tool that you use? I've noticed that it's mostly just switching 0x3F to 0x3C in the .bin files however the newer versions seem to require more work...
                              • TCN06
                                • Jun 2025
                                • 5
                                • France
                                #75
                                I'm reaching out about a BIOS flashing issue.
                                I was able to get ahold of a friend's CH341 programmer, which comes with an SOIC8 clip. However, I doubt the clip will work well for reading a chip that is soldered directly onto the motherboard.
                                On my HP 440 G10 laptop, the BIOS chip is a W25Q256JVEN. The issue is that in the ASProgrammer software, it only offers the following part numbers: W25Q256JV-IM-JM and W25Q256JV-IQ-JQ. Therefore, I don't know which one to choose.
                                I tried reading the chip with the clip anyway, testing both options, but the program only returns "FFs". I'm assuming this is due to a bad connection from the clip.
                                My question is this: even after I desolder the chip, which part number should I select in ASProgrammer? Do you think I should use different software?
                                Finally, before flashing the .bin files from rex98 , I want to make sure I don't make any mistakes. Is there a specific order I need to follow for flashing the different files?
                                Thanks in advance for your help!
                                • rex98
                                  • Feb 2023
                                  • 1289
                                  • Mandaue CEBU, Philippines
                                  #76
                                  use neo programmer search in google it supports ch341a
                                  • volinakis
                                    • Jan 2021
                                    • 2872
                                    • N/A
                                    #77
                                    ProBook 440 G10
                                    serial #5CD3474QB8
                                    try
                                    • TCN06
                                      • Jun 2025
                                      • 5
                                      • France
                                      #78
                                      The issue isn't the software. No matter what I do, the chip is "unknown". If I manually select the reference wb25q256jv and try to read it, I get an error message saying the memory doesn't match. The actual reference is wb25q256jven, but it's nowhere to be found.
                                      With Neo Programmer, it's the same thing. When I run the automatic detection, it does find something: AT24C01_7bits (ATMEL) and X24C01_7bits (XICOR). I still try to initiate a read, the software indicates it's a success, but in reality, nothing is read.
                                      Le souci ne vient pas du logiciel. Quoi que je fasse, la puce est "inconnue". Si je sélectionne manuellement la référence wb25q256jv et que je lance la lecture, j'obtiens une erreur indiquant que la mémoire ne correspond pas. La vraie référence est wb25q256jven, mais elle est introuvable.
                                      Avec Neo Programmer, c'est pareil. Quand je lance la détection automatique, il trouve bien quelque chose : AT24C01_7bits (ATMEL) et X24C01_7bits (XICOR). Je tente quand même de lancer une lecture, le logiciel m'indique que c'est un succès, mais en réalité, rien n'est lu.
                                      • geraldkacka
                                        • May 2021
                                        • 21
                                        • United Kingdom
                                        #79
                                        can someone help unlock hp pro book 440 g10
                                        sn: 5cd340bmdf
                                        thanks
                                        • rex98
                                          • Feb 2023
                                          • 1289
                                          #80
                                          use my post # 56 its v72 same a s yours flash both
                                          https://www.badcaps.net/forum/troubl...58#post3665458
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • iulik17d
                                            Intel Arc A380 videocard power limit remove - BIOS needed
                                            by iulik17d
                                            Hello everyone!
                                            The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                                            The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                                            01-10-2025, 02:33 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Phad
                                            Seeking help and advice to remove bios admin password – HP ProBook 4520s
                                            by Phad
                                            Dear All,
                                            Hope that this post is at the right place of the forum.
                                            I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
                                            The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
                                            As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
                                            After...
                                            11-10-2021, 12:05 AM
