any friend can unlock my 840 g10 TYA
HP 840 g10 bios
You must post the serial number/SNID or service tag with every bios request.
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Send to youAttached FilesComment
UnlockedAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
hp 840 g10
sn:5cd3176rvx
anyone can unlock this bios file_?Comment
first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.
you can permanently disable absolute in BCU. Use BCU to fill these DMI info:
Serial Number: 5CD3176RVX
Product #/SKU: 736J7AV
CT Number: PRVNT018JHZ06Q
Description: HP EliteBook 640 14 inch G10
BuildID: 23WWKRAZ601#SABY#DABY
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPgSguhKjhk8mEn7nVpDpVpnpqprqMqz.8Q
MAC Address : E0:73:E7:C1:FE:6FComment
Unlocked
Hp Elitebook 840 G10
Please unlock bios file.?Attached FilesComment
first boot press f10 reset bios to factory defaults and exit, 2nd boot reset security settings to defaults.Attached FilesComment
Please unlock bios
sn : C2L339042PAttached FilesComment
At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in to bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover or use BCU TOOLComment
It worked, thank you very much!Comment
Please give me information to see if there are any errorsComment
Please give me the full data sheet, I tried to find all the stickers to fill in but still couldn't! sorry to bother youComment
Serial Number: C2L339042R
Product #/SKU: 86T52US#ABA
CT Number: PRTUR00WBIF6NF
Description: HP EliteBook 840 14 inch G10
BuildID: 23WWWGBZ601#SABA#DABA
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBapaqauawb8bUbhcAfPguhKhkjhk8mEn7nVngpDpVpnpqprqMqkqz.3t
Một vấn đề nữa, tôi đã thêm tất cả ID hệ thống để thoát khỏi chế độ sản xuất, nhưng bây giờ tôi gặp lỗi Thông tin sản phẩmMPMkhông hợp lệ. Thông tin sản phẩm sau đây được lập trình trong bo mạch hệ thống bị thiếu hoặc không hợp lệ
Cirrus Discrete Amp Calibration Data
Nhấn phím cách để tiếp tục hoặc "Y" để nhập thông tin còn thiếuComment
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Today, 02:17 PM -
Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
Asus S533F serial L6N0CV190141266
Current BIOS firmware version is X521FA-305
Thank you!...-
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
- Loading...
