hp 640 g10 password bios
Hi, i need help with the admin psw on this bios:
SN: 5CD4106D9T
PN: 736J5AV
in the attachments both chips dump.
THKAttached FilesPremium supporters get full download access and other benefits.
Hi, Flash both V75 files from here > https://www.badcaps.net/forum/troubl...93#post3672293
And then fill in these DMI information using BCU
Serial Number: 5CD4106D9T
Product #/SKU: 736J5AV
CT Number: PRVNR078JJ8A7U
Description: HP EliteBook 640 14 inch G10 Notebook PC
BuildID: 23WWKRBZ602#SABZ#DABZ
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPguhKhkjhk8mEn7nVpDpVpnpqprqMqz.FQ
MAC Address: 2C-58-B9-DD-C7-3F​
Universally Unique Identifier (UUID): B3609123111FF548998E3E2BF4D90E50
UUID (standard format): 239160B3-1F11-48F5-998E-3E2BF4D90E50
MS Digital Marker: ​010000000000000001000000000000001D0000004B42484B512D374E4B51592D525657504B2D37374442572D5258394354Comment
Hi, it's flashed!
I'm trying to understand how everything works, as this is my first time using BCU (HP BIOS Configuration Utility).
Using the BADCAPS HP DMI Tool, I found the following information:
Product # / SKU: 736J5AV
Description: HP EliteBook 640 14-inch G10
Build ID: 23WWKRBZ602#SABZ#DABZ
MAC Address: 2C:58:B9
D:C7:3F
I'm trying to understand why these values are different and, more importantly, where I should enter all this information using the HP BIOS Configuration Utility (for example, the MAC address).
Could someone explain how this works and which fields need to be populated? or if i'm missing something?
Thanks in advance! -
by mrdemHello everyone !
This is the first time I’ve encountered the problem of extracting a password from a BIOS dump. The chip is marked 25lq64cvic.Could you please help me? I have a tablet from an unknown manufacturer. It has an AMI BIOS. I made a dump and tried to erase the code sections that I thought contained passwords. (I’m attaching photos of the sections and the dump via the link.) As a result, the tablet stopped turning on. I restored it to its original state by loading the previously saved dump. None of the standard passwords worked. I tried to decrypt the password using IDA Pro,...-
Channel: BIOS Requests ONLY!
by Darksands[SOLVED]
Laptop: Dell Pro 14 Plus, PB14250
Motherboard: PWB CMF34, Rev (A00).
Service Tag: 3YLQ8F4.
CPU: Intel® Core™ Ultra 5 processor 238V (8M Cache, up to 4.70 GHz) FCBGAEXX, Tray. Ordering Code: QQ8076606106. Spec Code: SRPN5.
BIOS Flash Chip: Winbond 25R512NWEQ.
BIOS version (via ME Analyzer by TechNoDev): 20.0.11.1815_COR, FITC 20.0.0.1329, SKU Corporate.
Symptoms & History: Initially, a black screen appeared, then the laptop rebooted, entered BIOS Recovery, and the flashing process started. After the flash and a reboot, it freezes...-
by Buzzfuzz2kHi Everyone,
I'm facing a problem with a locked bios with a password and i can't find how to remove it...
The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
the Computer is a Unowhy small pc
N° UYM6524702229
After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
My first attempt was to get the bios dump from windows...-
by SwatouHi everyone,
I bought a used Dell OptiPlex 3090 Micro with a BIOS administrator password that I cannot remove. Dell support refuses to help without the original proof of purchase, and the seller is unreachable.
I would like to try flashing the BIOS chip with a CH341A programmer, but I need a clean SPI BIOS dump for this exact model.
Here are my machine details:
Service Tag: 50P1BB3
Express Service Code: 10925963391
Form factor: Micro
I can share my current BIOS dump (read with CH341A) for comparison if needed....-
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
- Loading...
