l need remove the bios password of: UNOWHY Y13 EM_IG116_366B_V2.0.
EM_IG116_366B_V2.0 bios unlock
This topic is closed.
Read the rules before posting please:
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by piratiHello everyone,
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
- Loading...
