Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
bios hp 17-by1033dx
  • Vesko356
    replied
    Originally posted by alirafee
    not working
    no power
    What did you expect, didn't you read my comment?
    About your issue - I don't think the touchpad isn't working because of a bios problem, also there is a mismatch between the model you gave in the description and the one in the dump you uploaded (17-by1xxx vs. 17-by3xxx). Also there is a serial number mismatch. Maybe the back cover was changed or someone before you flashed an incorrect bios.
    Here is a virgin bios (same F.09 Rev.A) matching the model and type with the bios backup from your first post, both DMI and Windows Key are transferred:
    Premium supporters get full download access and other benefits.
  • alirafee
    replied
    not working
    no power
  • Vesko356
    commented on 's reply
    Read post #2.1
  • Vesko356
    Thanks for trying to be helpful, but the attached bios in your post is NOT OK, contains dirty ME Firmware (already initialized), DMI with different serials etc., and on top of that is corrupted. Try to help only when you're sure you're giving a correct solution.
  • startrek
    replied
    try this
  • musthafa
    replied
    try this
  • alirafee
    started a topic bios hp 17-by1033dx
    bios hp 17-by1033dx
    hi
    i need bios dump for 6050a3168901-mb-a02(A2) 6L
    my old bios dump has the mouse not working.
    bios hp 17-by1033dx
    snape01- 6050a3168901-mb-a02
    sn 5cg9117lzt
    thanks a lot
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • kinojk2
    ASUS Prime Z790-P (NON-WIFI) Bios dump and questions
    by kinojk2
    Hi, Thanks for all you do here.
    I have attached my 16MB dump.
    EDIT2: All hardware working fine, I think I just need to update my linux booatloader and all gucci
    EDIT:
    I can get into bios now! I reflashed as instructed elsewhere. With a minimal POST (just 1 stick of ram , GPU, CPU, no drives) I have loaded into BIOS. I am about to reinstall my other hardware components now.
    The clips are such a pain to use, soldering would be a great skill to have.
    Thanks for the advice in other threads!
    To answer my own question, I didn't...
    03-24-2026, 05:55 AM
  • dragic98
    BIOS Dump for Lenovo Yoga Slim 7 15ILL9 (83HM) LNVNB161216
    by dragic98
    Model: Lenovo Yoga Slim 7 15ILL9
    Machine Type Model: 83HM
    Motherboard ID: LNVNB161216
    TLDR: I would like to have the clean BIOS dump file for my laptop model.
    Issue: First, my speaker wasn't working/showing up, so I downloaded the recommended BIOS update (from Jan 4, 2026) on Lenovo Support for my laptop. This didn't fix the speaker issue after restarting, so then I shut it down and pressed the power button for 60 seconds to perform a reset. I'm guessing I somehow messed up the BIOS because now the laptop won't turn on even after trying the NOVO button on...
    03-27-2026, 11:45 PM
  • haitham sharabati
    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
    by haitham sharabati
    Hello engineers 😀,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
    💀 Problem:😅
    - Device shows “Administrator Password”...
    08-07-2025, 04:54 AM
