HP ZBook 17 G6 Endpoint Security Controller Problem
  • ameerrrr
    • Aug 2015
    • 41
    • syria
    HP ZBook 17 G6 DAXW3EMBAF0 REV F
  • hoaca388
    Badcaps
    • Jan 2022
    • 11786
    Serial number ?
    • ameerrrr
      • Aug 2015
      • 41
      • syria
      Originally posted by hoaca388
      Serial number ?
      s/n# 2TK03406L9
      • hoaca388
        Badcaps
        • Jan 2022
        • 11786
        s/n# 2TK03406L9
        HP ZBook 17 G6 Mobile Workstation RCTO Base Model
        • ameerrrr
          • Aug 2015
          • 41
          • syria
          It has been solved Endpoint Security Controller
          A problem has occurred
          • ameerrrr
            • Aug 2015
            • 41
            • syria
            Is it possible to solve the problem shown in the pictures?
            • leo037_2023
              DEMIGOD OF BIOS
              • Oct 2023
              • 63
              • Buenos Aires - Argentina
              try this BIOS .and let me know how it went, please don't forget.
              I will wait for your answer
              • ameerrrr
                • Aug 2015
                • 41
                • syria
                These messages appear and I don't know how to bypass them
                • FZG
                  • Sep 2022
                  • 111
                  All these informations need to be injected into the BIOS file. You may have to look around for them, usually they are all printed on stickers on the laptop back cover or on the inside of the device.
                  When you found all the numbers write them down and you can easily add them in Windows with a small program called "HP BIOS Configutration Utility (BCU)" which also lets you exit manufacture programming mode.
                  Search on Youtube for a video called " Solve Manufacture Programming Mode Is In Unlock Mode Error" on the channel "Dr-BIOS". Everything is explained there.
                  • ameerrrr
                    • Aug 2015
                    • 41
                    • syria
                    I tried but it didn't work
                    • FZG
                      • Sep 2022
                      • 111
                      Sure you followed all the steps in the video? Worked for me several times. Besides that, you can check the original BIOS dump (which you hopefully have). All DMI infos (serial number, feature byte etc.) should be in there somewhere. Copy them into a clean BIOS file and flash it.
                      • ameerrrr
                        • Aug 2015
                        • 41
                        • syria
                        Could you please send me the link of the video and method to my inbox
                        • Arsalan455
                          • Oct 2019
                          • 53
                          • Pakistan
                          HP zbook 17 g6
                          display ok hp logo hang PLZ REPAIR
                          S/N 5CD034CXF7
                          daxw3embaf0 REV F
                          • Arsalan455
                            • Oct 2019
                            • 53
                            • Pakistan
                            hi plz repair bios
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11786
                              Originally posted by Arsalan455
                              HP zbook 17 g6
                              S/N 5CD034CXF7
                              daxw3embaf0 REV F
                              • Arsalan455
                                • Oct 2019
                                • 53
                                • Pakistan
                                ok problem solve thnak you sir
                                • samirf76
                                  • Jun 2016
                                  • 8
                                  • iraq
                                  hi every one
                                  helpe me please to clean me this bios
                                  HP ZBOOK G6 17
                                  CN : 5CD949488C
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11786
                                    Originally posted by samirf76
                                    hi every one
                                    HP ZBOOK G6 17
                                    CN : 5CD949488C
                                    HP ZBook 17 G6 Mobile Workstation IDS Base Model
                                    • samirf76
                                      • Jun 2016
                                      • 8
                                      • iraq
                                      thanks but it s not working just heigh speed fan
                                      • kolebbk
                                        HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                        by kolebbk
                                        Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                        HP Endpoint Security Controller problem
                                        there is a problem with the hp endpoint security controller on the unit
                                        I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                        09-04-2024, 12:44 AM
                                      • fede77
                                        Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                        by fede77
                                        Notebook HP ProBook 450 G8
                                        ProdID 2K8L1LT#AC8
                                        Mother: DAX8QAMB8D0 REV D
                                        The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                        03-10-2025, 07:12 AM
                                      • lamonde
                                        850 G6 Endpoint Security Controller Problem
                                        by lamonde
                                        Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                                        and there is no soud after flashing new bios, may be have some solutions?
                                        ProdID: 4YD62AV
                                        SN: 2TK9500V8X...
                                        01-15-2025, 09:31 AM
                                      • biednybelfer
                                        HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                                        by biednybelfer
                                        After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                                        Mainbard model:6050A3044201-MB-A01 (A1)​
                                        Serial Number: 5CG0275ZLV
                                        (I'm not allowed to upload files with the extension bin, so I upload zip)...
                                        10-05-2024, 05:04 AM
                                      • M.Salman
                                        zbook 15u g5 Endpoint Security Controller Problem
                                        by M.Salman
                                        hello masters i have a zbook 15u g5 after changing the nuvoton i got end point security error i dont know how to remove that error i attached my both bios plzz help me its urgent....
                                        04-07-2023, 04:15 AM
