ASUS Zephyrus GX701LXS BIOS request
  • skipron.rm
    skipro.rm
    • Nov 2020
    • 9
    • Kosovo
    Hello everyone, trust you're doing well.
    I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
    I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
    However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
    The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
    My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining the dump with the updated 311.
    Unfortunately, I've encountered an obstacle: the "BIOS Region.bin" in the dump is 12.288 KB, while the main BIOS on the updated version is only 6.016 KB.
    I'm looking for help in extracting the necessary portion of the BIOS.
    Any help would be greatly appreciated.
    P.S. Tried to attach the bios dump and extracted bios-es, wasn't allowed, hope you understand.
    Here's the link do download those file badcaps.net
    Badcaps - Capacitor Search Engine & Electronics Repair Forum
    • 22035
    Post your backups in a zip or rar attachment.You can`t post a *.bin
    https://www.badcaps.net/forum/troubl...sting?t=103570
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • skipron.rm
      skipro.rm
      • Nov 2020
      • 9
      • Kosovo
      My sincere apologies!
      Here's the laptop details:
      Device: Laptop
      Brand: ASUS ROG Zephyrus S17
      Model: GX701LXS-HG040R
      SN: L5NRKD013017202
      Board No: GX701LXS R1.3
      Attached, you'll find a zip files containing the original BIOS dump and the latest BIOS from ASUS website and the extracted/decomposed files.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12366
        Device: Laptop
        SN: L5NRKD013017202
        GX701LXS
        • skipron.rm
          skipro.rm
          • Nov 2020
          • 9
          • Kosovo
          @hoaca388​ Thank you! I genuinely appreciate it!
          I'm eager to learn, and I hope I'm not causing too much inconvenience by asking.
          Can you recommend a source that I can use to teach myself? or, If you could share the steps you've used... I'd truly value it.
          Thanks again. Wish you the very best!
          • skipron.rm
            skipro.rm
            • Nov 2020
            • 9
            • Kosovo
            Unfortunately, after flashing the BIOS the issue remains unresolved.
            The laptop is stuck in a boot loop and doesn't power on
            • hoaca388
              Badcaps
              • Jan 2022
              • 12366
              @hoaca388 Thank you! I genuinely appreciate it!
              Ok, look at the pictures, pic 2 , extract by winrar.
              • skipron.rm
                skipro.rm
                • Nov 2020
                • 9
                • Kosovo
                Amazing! @hoaca388​ thank you for sharing this info.
                I downloaded the latest ASUS BIOS update, v311, which I believe is 256K larger than the existing dump.
                Using the appropriate FIT, I extracted the dump and utilized AMI BIOS Guard to break down the v311.
                The objective was to get the BIOS region from it, in order to replace and rebuilding the dump.
                However, the file from v311 turned out to be smaller than the BIOS region in the original dump.
                With the original BIOS the laptop powers on, but doesn't post. With the new BIOS, it's stuck on bootloop.
                Do you have any idea on whether the issue lies with the new BIOS or if there might be something else causing this behavior?
                Thank you for your time and assistance. I genuinely appreciate it!
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12366
                  I think your laptop has another error, not the bios.
                  • skipron.rm
                    skipro.rm
                    • Nov 2020
                    • 9
                    • Kosovo
                    It is a possibility, though I am hoping that it is not the case.
                    I'd expect the laptop to have the same behavior, not posting.
                    I'm hoping that the new BIOS is the reason for it being stuck in the boot loop and I'll continue my search for a solution, and a new bios as well.
                    Thanks!
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
