Dell latitude E6400 bios password reset
  • soorooshsg
    • Apr 2014
    • iran
    Re: Dell latitude E6400 bios password reset
    hello i need bios admin password... please help! my service tag is GS8M3L1-1F5A
    • Itguru
      • Apr 2015
      Hi out there,
      I also want to ask for your help as I wasn't able to reset the admin password.
      My service tag is: 4XDNQ4J
      Cheers,
      ITGuru
      • Mcnumby
        • Apr 2015
        • Usa
        Originally posted by wallyoz7
        The bios password is stored in an eeprom chip. Dell e6400 have a single chip while
        e6410 has dual bios chips. Replacing these chips will remove the bios password.
        The bios chips are lightly welded to the motherboard, so a hot air rework station
        can unweld these chips in 5 minutes and a new set of programmed chips can be placed.
        If anyone is struggling with the password issues , reply to my message , I do not
        charge for helping. I do this for a hobby and to help people out.
        Yes there are bios generators out there (with a fee of course), but Im not to fond of giving out my credit card to any unknown websites. Just be careful out there.
        Please please help me! I have tried everything! I have a dell latitude E6400 service tag FD4NMK1 service code 33445616113. I used one of those online generators and tried all 3 different passwords to unlock the bios -the last one I thought worked but then a screen came on asking for another password for HDD? - no clue what that means- is that the same thing? Anyway I could not get out of that screen so I rebooted thinking I could I access that screen again but now none of passwords work! Anything anyone could do ?
        • trebo
          • 514
          • Wales, UK
          It must have worked if you were asked for a HDD password,
          a HDD password means that the hard drive has a password on it also, to get the HDD password enter your service tag into the generator like this, ****FD4NMK1
          but first you have to get the bios password again, I can only suggest that you remove the CMOS battery for 10 minutes or so and then try again
          • mrtuffguuy
            • Apr 2015
            • USA!!!!!
            e6400 I need a bios admin password if possible. don't know much about this stuff...th service tag is 2W1M4K1 THERE ANOTHER #THAT SAYS EPRESS SERVICE CODE AND ITS 6291194257. THANKS A MILLION MAN!!!!!!
            • trebo
              • 514
              • Wales, UK
              #26
              Try these from your service tag,
              cavqy7wh
              isbgfbpm
              mozr440kMisVn24O
              most likely the third one is yours, but try the other two if it don't work
              Here is a link to the Generator that finds lots of the passwords of older laptops
              http://bios-pw.org/
              • walkingdude
                • Nov 2014
                • 4
                Greetings,
                Also have a Latitude E6400 with service tag J0P46K1-2A7B and cant get past the password. Have tried several different methods, just wandered if anyone could help. Any assistance much appreciated.
                • trebo
                  • 514
                  • Wales, UK
                  #28
                  Originally posted by walkingdude
                  Greetings,
                  Hello walkingdude
                  Try this, Nzqf9IdCyA03PDX1
                  enter password then hold down control and press enter, you may need to press enter twice
                  passwords are case sensitive so enter as seen
                  • walkingdude
                    • Nov 2014
                    • 4
                    Brilliant work trebo,
                    Worked first time, much appreciated.
                    • trebo
                      • 514
                      • Wales, UK
                      #30
                      well done, just glad to help
                      • Life Goes On
                        • May 2014
                        • 264
                        • Curacao
                        #31
                        Are you use a software programmer to finding the key
                        The Night Drop Down, I Will Keep Try Until..., You Never know.
                        Dushi Kòrsou, Nos Tei.
                        • trebo
                          • 514
                          • Wales, UK
                          #32
                          dogberts generator as found here, http://bios-pw.org/
                          It does the older Bios passwords but not the newer ones, mores the pity
                          more info on this link, http://dogber1.blogspot.co.uk/2009/0...ered-bios.html
                          • Life Goes On
                            • May 2014
                            • 264
                            • Curacao
                            #33
                            Interssant thank you for sharing.
                            • walkingdude
                              • Nov 2014
                              • 4
                              Hi Trebo,
                              Just wandered if I could pick your brain again. Had a 2nd E6400 which I already had the BIOS password for but it also had "Remotely Managed " trusted drive which I could not get passed. Ended up buying a second hand drive from ebay and swapping them over which did the trick. Still have the old drive which I would like to use as a spare external hard drive and just wandered if it was possible to get by this authentication system. Cheers for any help.
                              • trebo
                                • 514
                                • Wales, UK
                                #35
                                Hi Trebo,
                                This may be possible, but (and a big but at that) the hdd has to go back in its original laptop and the hdd has to be the one that came with the laptop when it was bought (I believe that's to be the case anyway) or it may just be that the hdd needs to be in the laptop that it was in when the password was put on the hdd
                                Then send me the service tag of that laptop
                                • walkingdude
                                  • Nov 2014
                                  • 4
                                  Hi Trebo,
                                  Original service tag number is #8ML22M1-2A7B
                                  • trebo
                                    • 514
                                    • Wales, UK
                                    #37
                                    Hi Trebo,
                                    Hello walking dude
                                    Have a go with this, PbiQmgezPB2zMt6V
                                    Best of luck
                                    • orcatraz
                                      • Apr 2015
                                      • 4
                                      Hi, I need a locked BIOS password.
                                      Dell E6410
                                      System Number: 7J9DYN1-2A7B
                                      Thanks for any help...... Mike
                                      • trebo
                                        • 514
                                        • Wales, UK
                                        #39
                                        Dell E6410
                                        Hello orcatraz
                                        Try this, en429oV37aH94drq
                                        the password is case sensitive so enter as seen
                                        best of luck
                                        • orcatraz
                                          • Apr 2015
                                          • 4
                                          Thanks!!!! Worked perfectly....
                                          Mike
